Question about Champion 24 in. UH-200B Built-in Dishwasher
How to connect power to champion uh-200b single phas
I have hookedup 220v ( l1 and l2 and nutural) but not working and look like no power in when pushing start
    Scholar:
  • 86 Answers
I don't see the date when you posted this problem but it is still on unsolved suport section. So I try to let you know that all Champion dishwashers need the first inital start up . That is make sure water is in the booster , Locate the Installation and service toggle switch on the extreme left side of the control box.Prime the booster .
Let me know if you still want more information about this unit. God Bless,
Posted on Jul 11, 2009
A transformer rated 480/110/220 volt, single phase. The currents on the secondary are 16 amps on L1, 27 amps on L2. What is the primary current on the transformer?
Assuming L1 terminals are the 110 V output and L2 are the 220V output, then the theoretical 440V input current for a 100% efficient , i.e. lossless, transformer would be 17.5 amperes.if the secondaries are delivering the specified currents. More realistically the input current might be 2 to 5% higher since transformer generally run at 95 to 98% efficiency. 18.5 amperes would be an approx result.
Amps at 440 V = ((16 x 110) +(27 x 220)) /440
Apr 18, 2017 | Heating & Cooling
Can you get me a diagram on electrical hookup?
Hello;
My name is Peter. I am a retired field service technician.
I do not know if you have a 3 wire or 4 wire connection. For a 3 wire connection you need 15 AMPS at the breaker box. For a 4 wire connection you need 30 AMPS at the breaker box.
Three wire hookup. Center wire goes to N, the other two wires are hot. It makes not difference witch of these two wires go to L1 or L2. The ground goes to the cabinet.
Check the voltage - With a volt meter between L1 & N = 220V, L2 & N = 220V, L1 & L2 = 240. These readings are general. You may get something like 210V instead of 200V
Mar 10, 2015 | Dryers
Jandy Zodiac FloPro 2HP connecting Red Wire to which screw L1 or L2?
follow the owners manual.
if you are hooking this pump up as 220v, you will have two hot wires. one goes to L1 and the other to L2. it matters not which is where as they are both supplying power. be sure to connect the internal ground wire AS WELL as the bonding wire to the outside lug
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
Emerson 48 frame pool motor 110v 220v wiring diagram
L1 and L2 is where you hook up the two powers (lines) and the green goes to ground.. look close you will see the L1= L2 in the plastin next to the power screws
Sep 14, 2013 | Aqua Flo Pool & Spa
I am trying to wire a dayton booster pump. it shows a L1 and L2 connection on the 115v connection. L1 goes to P1 L2 goes to T4. on the 220v connection it shows L1 and L2. L1 goes to wire P1 and L2 goes...
The power cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground
Jul 17, 2011 | Kitchen Ranges
What do all the L's adjust L1 L2 L3 etc..?
L1 and L2 stand for "Line 1 and Line 2". These are the two incoming hot legs of a single phase, 220V electrical supply as is typical for residences. The N stands for the neutral or grounded conductor. This is the white wire in a residential system
i hope this puts a little light in the subject
Jan 24, 2011 | Cobra 29 LTD CB Radio
Had a power cut and now the fridge doesnt work - model is a Whirlpool 470, cant find any obvious fault, but fridge is not getting full power, only reaches 140v instead of the normal 220v.
Never heard of 220v refrigerators, but half voltage means that either L1 or L2 is defective. Is it fed from fuses or circuit breaker? Make sure that your incoming power line has 220v from L1 to L2.
Check the fuse or circuit breaker with volt meter, make sure you have 220v from L1 to L2
Apr 15, 2009 | American Standard Colony 1583.470.020...
Champion 24 in. UH-200B Built-in Dishwasher Logo
80 people viewed this question
Top Champion Dishwashers Experts
bengsoon Neo
Jude24
Trevor Turner
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
