Lp30 laminator, paper jam
Laminate is jammed at the rear of grey front rollers, laminate is visible as a double furl at top and bottom of both rollers.
2 Suggested Answers
  • 86 Answers
SOURCE: I have a Rexel LP30 Laminator and the paper has
Gently try cutting the laminate and running you machine in reverse while pulling on laminate. Be sure not to cut your lamintator rollers as scarring will leave marks on your jobs. Hope this helps . leave feedback
Posted on May 17, 2010
Do I insert the printed paper into clear pouch & just put these 2 items into Smith Corona Laminator LX900? Do I need a heavy paper protector to surround these 2 items? How do I order a protector?
use what is called laminating pouches
you put what you want laminated in the pouch, centre it so that the edges all have the same space, wait until the green light on the laminator appears and enter the pouch with the folded end in first.
It will slowly move through and seal off as it goes
make sure that the pouch is entered square to the rollers or it will crease the finished product or jam the laminator
there is no need for any additional equipment
Jan 08, 2017 | Office Equipment & Supplies
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
I jammed the laminating machine, so I unscrewed and opened the machine...but now I don't know how to roll out the paper? Please help me find a way to take this out without breaking the machine!
Carefully try to turn the roller one direction and then the next. If they move, you will see the feed direction the paper loaded from. Carefully move the rollers in the opposite direction letting the paper unwind. Do not force the gears. Hopefully the paper is not fused to the rollers.
Mar 03, 2015 | Scotch 9" Tl901 Hot Laminating Machine /...
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
Laminator squeals
The paper is fed into the laminator by rollers usually a top and bottom, one of them is usually made of silicone(rubber) check to see if tose rollers are turning, you may have to pull some covers off to see the rollers, but usually you can look in the throat where the paper is fed in and see these rollers with a flashlite. Not sure of the brand, big or small laminator, good luck. If rollers are not turning, some are belt driven, some are motor driven, could even be a control board or switch.
Sep 24, 2013 | ACCO HeatSeal Ultima 65 Roll Laminator...
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
I have a Rexel LP30 Laminator and the paper has stuck around the rollers - is there a way to get this out without breaking it? Thanks!
May 15, 2010 | Office Equipment & Supplies
The lamination paper is stuck. never went thru the other side. How do I open it and un jam it? Please help ITS THE XEROX XRX-951L laminator. I couldn't find t n your list
you need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
May 26, 2008 | Xerox Phaser 8500/DN Printer
Paper stuck in roller
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the control panel button.
Mar 31, 2008 | Brother HL-2040 Laser Printer
k24674
jasbo
jasbo
