Question about Kodak Easyshare Z812-IS Digital Zoom Digital Camera
Card will not format
No card will format
Memory card not formated operation failed
Sometimes, Due to viruses or hidden data in the memory card, the handset is unable to format the memory card. so if u format it from a pc, using a card reader, your mem card will surely get formatted easily.. But if there is some technical problem in formating, download HP DRIVE KEY BOOT UTILITY It repairs up and formats the corrupted data and your memory card will be ready to use again .. Happy formatting !
May 09, 2011 | Nokia 2690 Cell Phone
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
Apr 15, 2011 | Nokia 6630 Cellular Phone
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
How to i format my memory card for nokia 7373, its a new memory card, but when incerted it says, memeory card not formatted.
Just goto Menu -> tools -> memory
1. select Memory Icon.
2. Press Options
3. Select Format Memory card
4. Thats all.. your memory card will be formatted and ready to use.
I hope this solves your problem.
Thanks
Mar 10, 2010 | Nokia 7373 Cellular Phone
My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
Aug 15, 2009 | Kodak EasyShare Z740 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
Memory card requires formatting- I select continue then it says "formatting will delete everything on memory card-I select "continue" then it reads "formatting" and repeates itself
1. Make sure your SD card is not locked so the camera can format the card. If the camera still cannot format the card, try to format the card with a computer. If this doesn' t work, the card may be defective.
If the computer can format the card, the put the card back in the camera and then the camera should be able to format the card. The camera MUST format the card before the camera can save to the card.
Jun 11, 2009 | Kodak EasyShare V550 Digital Camera
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
How to format the microSD?
actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
otherwise their is a standard Sd format and u can use that to format
You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
http://www.sdcard.org/about/downloads/
May 05, 2008 | Kingston 2GB Secure Digital Memory Card
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
Kodak Easyshare Z812-IS Digital Zoom Digital Camera Logo
74 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
