Question about Nikon LS5000 Film Scanner
Nikon ls 4000 ed
35mm slide scanner
Looks like I fried my firewire port due to cable being inserted backwards.
  • 1 more comment
  • barjak Oct 15, 2007
    Please respond
  • barjak Oct 16, 2007
    You response to my problem was not even close to my problem.  The computer firewire board is operating OK.  Nikon scanner does not work on another computer either.
    Can I replace the firewire board on the Nikon LS 4000 ED scanner?????
  • barjak Oct 20, 2007
    We're getting closer to success.
  • 363 Answers
Now thats as daft as the last premium problem I answered.
Seriously though, have you got another firewire device that you could plug your port into to prove the port. Or have you another port to plug your device into to prove the failure point one way or another?
Posted on Oct 10, 2007
  • Martin B
    Martin B Oct 15, 2007
    If the Firewire port is on a PCI card then open the PC and remove the card. If you are lucky there will be just a 20mm fuse to replace.
    Good luck.
  • Martin B
    Martin B Oct 19, 2007
    Sorry for misunderstanding which port you were talking of.
    You will find that the port and control circuitry of the scanner are all built on one circuit board. There is likely a blown component on this board, with luck it will only be a fusible link or resistor near the socket to replace otherwise the Firewire interface chip may have fried.
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
Otherwise, if you have windows 7 32bit click here:
To check bits, go right click on My Computer, Properties, and you will see it.
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Oct 02, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Download the Nikon scan application here: Nikon Scan
There is also a firmware update for this model. After installing the Nicon Scan software that includes the scanner driver (ensure that scanner is recognized), do the firmware update.
Follow instructions on site and do not interrupt firmware update procedure, or that may damage the scanner.
Coolscan IV / LS40 1.2.0 firmware update
Aug 20, 2010 | Computers & Internet
Need a new driver for coolscan 4000 ED for Vista.
You can download the Vista Driver at this link: 4.0.3 full version - Vista only
If this information was helpful, please give me a big thumbs up when you rate my answer.
Feb 03, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Color balance is bad
Have you tried cleaning the slide holders/adapters?
Jun 11, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Trouble ejecting slide from SF200 nikon coolscan 4000 ed
open the case of the scanner, and check to make sure that the ejection mechanism is not malfunctioning, or jammed someway.  If this is not the problem, try using thinner slides as thicker ones could also cause this.  If all else fails try un plugging the scanner for a few minutes, and try again.
Jan 10, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
USB cable from scanner to new Dell Optiplex 755
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Jan 02, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Firewire. USB2
Either or is my understanding- the scanner will accept either. I can see no need for both.
Sep 01, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Open Questions:
Nikon LS5000 Film Scanner Logo
148 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
