Question about Yamaha RAV-300 Remote Control
Remote dead Do not work anymore
2009 a4 driver's door won't open with remote
if there is an autozone close to you they have a remote tester will tell you if the battery is dead
Mar 12, 2015 | 2009 Audi A4 2.0
Keyless entry remote doesn't open doors anymore on my 05 ford focus
Sounds like the contacts in the buttons are not making contact.. you may want to try taking the remote apart and cleaning the contacts and seeing what happens. If the remote is truely dead you may need a new remote
Feb 01, 2015 | Ford Cars & Trucks
Remote may be dead
Check it for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside the battery compartment, before inserting batteries to make sure that the batteries are in good contact.To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. It has details about how to check a remote control.
Nov 30, 2013 | Sony Rmt-d187a Dvd Remote Control
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
My remote control didn't work anymore. there's no light in the remote whenever i press it. Is these a problem of a battery in the remote or something else?
If the status light no longer illuminates when pressing the remote (where it did before), the most common reason is a dead battery. If, after changing the battery, the light still fails to illuminate, the problem may be corrosion on the contact points for the battery or, the buttons are not making contact on the circuit board.
Nov 15, 2010 | Remote Start System
2000 JGC starts and goes dead in 3-4 seconds worked fine until wife came out for lunch tried the remote and it wouldn't work so she used her key got in started it and the horn blowed once so she pushed one...
ok i know this might sound wiered but i just had the samething happen what i did was i cleaned the key with soap and water dryed off , locked the door with key and unlocked with key then got in jeep tryed starting it ,it started right up gauges all work now and windows work and running fine doesnt shut anymore.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
Remote start will not work anymore..already checked fuses????
try to change the battery in the button mite be to dead t ostart but not dead to unlock doors.
Dec 15, 2009 | 2006 Pontiac G6
Electronic key won't work after dead battery??? battery went dead and when recharged the electronic keys won't open the doors anymore?
If you have the Vehicle Owners Manual it will instruct you how to reset the Electronic Remote(s) as disconnecting the Battery or a totally discharged battery removes all power from the On Board Chassis Computers memory. Therefore you must reset the Remote(s) so that the On Board Chassis Computer can recognize them. If in Doubt, please consult your Chevrolet Dealer to rectify the problem.
Dec 07, 2009 | 2006 Chevrolet HHR
Televison & Video Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
