Question about Maytag MFF2557HE Bottom Freezer French Door Refrigerator
Model mff2557hew maytag - replaced main control twice and will work fine for a couple of weeks then compressor will not come back on. any ideas?
4 Suggested Answers
SOURCE: Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
Posted on May 30, 2008
aborcass
  • 2651 Answers
SOURCE: maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
Posted on Nov 10, 2008
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
Can I repair or rebuild a locked up ac compressor pump or do I have to buy another ac compressor 2006 Impala 3.9 V-6?
I don't know if my air condition services were cheating me but I had twice problem with the compressor and after two different checkups both time they told me I had to install a new compressor. and that repairing it was not a good idea.
Oct 25, 2015 | AC Cars & Trucks
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
I have a Maytag neptune model mdg3000aww, and the spin cycle is not working. I have replaced the control board, yes the r11 resitor was burnt, the wax motor, yes the door lock light comes on now, and...
Did you check the out of balance switch on the bottom.I FIXED ONE LAST WEEK. All I did was push it a couple of times real hard until I heard it click. You can activate the diagnostic mode & see if the out of balance switch is activated. That is what I did after I found out the out of balance switch was activated & stuck on, I pushed it twice & it deactivated & spun out fine.
Sep 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag mff2557hew fridge not cooling. Freezer ok.
Jul 27, 2009 | Maytag MBB2256G Bottom Freezer...
Maytag msd2652keu side by side compressor gets hot shuts off and unthaws freezer i unplug 4 a few hours plug in and works 4 a couple weeks any idea
Check to make sure condenser fan is working (this is the fan located near the compressor). It should be running at the same time the compressor is running. If it isn't, make sure there is power to it by testing with a voltmeter. If there is, replace the fan. If the condenser fan is working, clean the coils and check the evap fan.
Jun 25, 2009 | Refrigerators
Maytag refmodel number mff2557hew
Nov 09, 2008 | Maytag Refrigerators
May 29, 2008 | Maytag MSD2732GR Side by Side Refrigerator
My refrigerator/freezer intermittently gets warm
GE had a problem with their units I dont see which model you have here but if you pull the unit out and look on the back wall lower right side and see a cover plate with about 10 screws in it ther is a main ctrl board in the and it controls just about everything in your unit There is a relay on the board that controls the compresser as well it maybe sticking at times. The crappy part is you can not just replace the relay you have to replace the whole board.. if this is the case post the model # and i will get you the part# and cost on a replacwement it is something you can do yourself
Jan 24, 2008 | Refrigerators
MAH3000AWW
Replace both the main control board and the wax motor. This sounds like a computer chip malfunction
As far as the squeak, make sure it is not the bearing located at the back of the tub under the large pulley.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MFF2557HE Bottom Freezer French Door Refrigerator Logo
21 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
