Question about Dishwashers
E3 error on candy cdi4545
I have a candy slimline dishwasher cdi4545. It returns an e3 message without completing its cycle. Does anyone know which problem is indicated by e3?
  • 641 Answers
SOURCE: E3 - Non Release of Tablet
The E3 code means - Longer heating time.Not reaching required temp. Cause - Malfunction of temp. sensor or heating element. Good luck !
Posted on Jul 21, 2007
  • 1314 Answers
SOURCE: Error e3?
i need your serial num its important 17
Posted on Jan 04, 2008
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Posted on Jan 23, 2009
SOURCE: Danby dishwasher E3 error
Same issue here so I just got off the phone with Danby. They said the E3 means the water is not hot enough when it goes into the machine. Now I dont know your guys situation but I let the water run hot until I cant touch it anymore, then I turn on the machine and plug it in. So it sounds like the heating mechanism is not working properly and does not heat the water to the appropriate temp to continue with the cycle. I will say that their support was really friendly and she informed me that since it was purchased less than a year ago it would be covered under the warranty. She gave me the number of a local repair shop. Lets just hope they dont tell me nothing is wrong with it because my water temp is fine. I will let ya guys know. Here is the number for Danby that I called. General office: 419-425-5052. Good Luck!
Posted on Feb 13, 2009
Daniel S
  • 4323 Answers
SOURCE: E3 error code on Candy
Hi
E3 error code in your Candy is a temperature error, which means that the unit is not reaching its desired temperature level. However, as the unit will heat water then it means that the heating element located on the left is fine. The next thing that should be checked is the temperature sensor (thermostat/thermister), as that might not be responding, this part is located at the bottom & can be located beneath the door. Hope this helps...please post back with its model no. for further assistance.
Daniel
Posted on Dec 08, 2010
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Water heating time out or fault
The dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element.
Check water heating element wiring
Check wiring to main control module
Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
Candy CDI4545 turn off delay start
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
Dado
May 17, 2012 | Candy CDI4545 Builtin Dishwasher
The cuff appears to be working, but always returns E3.
E3 error code is an Error Determining Measurement Data. This can be caused by movement of the wrist, hand or arm during the measuring function. In which case, sit very still with your wrist at heart level, until the measuring cycle has completed.
If this continues to happen, contact HoMedics (the manufacturer) Customer Support Dept at 800-466-3342.
Hope this helped you. Please let me know.
May 12, 2011 | Walgreens Automatic Wrist Blood Pressure...
Kenwood dishwasher Comes up E3
I do not know the Kenwood dishwasher, hence I do not know what the E3 error is, but many dishwashers require a sustained pressure of at least 30 psi.
Can you please post the model number of your Kenwood dishwasher?
Apr 11, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Stops pumping in middle of program
I know it is a bit late, but maybe it would help the others.
This E3 error means, that the water temperature did not reach desired level (for example 60C if you are using 60C program) in a given time.
The dishwasher starts the heater and waits for example 10 minutes for the water to reach the temp.
The heater is located on the left side of the dishwasher - it heats
water flowing from the bottom bowl to the sprinkler on the top.
There can be few reasons:
- the heating device is dead - easy to check - if the water is hot when E3 appears, then this is not the case
- the water duct from the bottom bowl to the top sprinkler is messy, and needs cleaning (there are some rubber pipes of quite small diameter)
- the temperature sensor (thermistor) is dead / not responding fast enough. It is mounted to the bottom bowl and can be reached from the front cover, under the doors.
Hope it would help to somebody.
I have already had this and few other problems. All of them have about 5-6 reasons to appear, and I think I know all of them for now :-)
For me, knowing what to expect and how to fix each E-something, this dishwasher is perfect and will last forever :-)
Regards,
Piotr
Jan 19, 2009 | Candy Dishwashers
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 | Dishwashers
Dishwasher Hoover HD98E
E3 means water is "not heating" for this model. Check the heating element, thermostat/thermistor or printed circuit board with power OFF.
Sep 11, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
May 10, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error e3?
Apr 02, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
