Question about Kenmore Washing Machines
Washing machine 110.2800
Brand new machine making a funny noise when in the wash stage
  • 958 Answers
SOURCE: washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Posted on Feb 12, 2008
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
landsend
  • 1066 Answers
SOURCE: whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Posted on Apr 01, 2009
SOURCE: Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
Posted on May 06, 2009
  • 864 Answers
SOURCE: Washing machine is making a grinding noise when it is spinning, and adjutates with a noise
The clutch or motor bearing is failing.
Posted on Jun 02, 2009
Replaced beko motor brushes on washing machine and they are making funny noise
Please remove and reset the brushes are it could be out of alignment , Please check this link for tips: Brush setting
Feb 01, 2013 | Washing Machines
My washing machine is making a funny noise when it spins
well this is not very help full, funny noise's? hhmm? ok, cat stuck in the drum? no? lets try the bearings wearing out or braking up? broken spider? yes i did say spider, its the bit that holds the back of the drum to the driving shaft!! maybe you left a coin in a pocket and its found its way behind the drum, lets hope it dont find its way into the pump as well! broken suport springs? any number of other things????? but as for funny noise's,,, im stumped now,,oh, yes, just the one spring's to mind! my dog snores??? but he's no a very good washing machine!!!!!!!!!!!!!
Oct 20, 2009 | Washing Machines
On rinse part of cycle...makes weird noise and doesn't drain the water out.It is actually a RAX4232 PQO
If the motor is running you likely have something caught in the pump. The fins in the pump hitting something will make funny sounds. Brand and Model number always helps.
Aug 19, 2009 | Roper RAX4232KQ Top Load Washer
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
The spin cylcle does not work . It makes a funny noise and does not spin
the drain is probably clogged you'd be surprised home much is in there
Apr 26, 2009 | Washing Machines
Whirlpool AWM1200 washing machine wont advance at certain stages
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
At firt, the washer would take 2 hours to wash clothes and then it started to take longer and longer. Sometimes the washer would make funny noises.
Turn off the water to the washer. Remove the hoses from the back of the washer. Carefully remove the little filter screens from the hose connections in the back of the washing machine. Clean and replace them. Your laundry should be done is less than 20 minutes now.
If it continues to make funny noise, write back.
Sep 26, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
