Question about Dryers
Bush tdv6w tumble dryer wont start just flashes lights and beeps
Dryer is only two weeks old and wont start just beeps when I try to start it, it worked fine yesterday when I used it, can anyone help me to how to get it running again or is it a fault with the dryer
    Scholar:
  • 73 Answers
All these sound like good advice but in addition - there is a re-set button on the back of this machine, push it and see if the problem continues. If you still have the same problem after re- setting your machine please call their customer service line at 0345 640 2020.
Posted on Sep 24, 2014
5 Suggested Answers
no85
  • 4 Answers
SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Posted on Mar 20, 2009
  • 76 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
Posted on Feb 26, 2007
futureloginn
  • 734 Answers
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Posted on Jul 16, 2010
I have a tumble dryer bush tdv6b got from a friend not very old was working fine now its not doing anything apart from a slight buzzing noise tried the reset at the back does nothing thanks
MOST PROBABLY THE CAPACITOR BESIDE THE MOTOR NEEDS REPLACED. http://www.buyspares.co.uk/tumble-dryer/tdv6w/capacitor/product.pl?pid=4058219&shop=bush&path=864668&refine=capacitor&model_ref=8702213
Jan 31, 2016 | Dryers
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
I have a bush tumble dryer TDV6W and each time its switched on it trips the electric whats the cause?
guessing the heating element has shorted to ground . call for service.
Jan 17, 2015 | Dryers
I have a bush tumble dryer TDV6W but when I put it onto the extra heat part the botton flashes and cuts my electric out, whats wrong with it, its only 4 months old
Hi Margaret, 4 months old? warrenty problem! it may also be a shorting temperature sensor. How old is the wiring in your abode? Possibly circuit breaker faulty.
Dec 30, 2014 | Dryers
Less than a week old u go to turn it on and the weight and airing light flashes and it beeps
There is a re-set button on the back of this machine if you still have the same problem after re- setting your machine please call their customer service line on 0345 640 2020 to assist you further.
Jan 11, 2014 | Dryers
Model tcl770 tumblecdryer wont start to tumble. Power light in and beeps. Filters etc all clean. If I press any of other buttons they all flash. Any advice please.
Hello Hazel
You need to check this parts.
Check the drum belt
Check the idler pulley
Test the motor
Best Regards
Neciforo Llanto
Sep 30, 2013 | Dryers
Dryers Logo
2,832 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
