Question about Panasonic GigaRange KX-TG5432 Cordless Phone
One handset not working; the other starting to stick
One of the handsets had sticking keys (had to press several times to get it to "engage") and now can only be used if you answer that handset.  Still can't dial out or review phonelist on it, tho'.
The second handset is now starting to stick and I don't want to wait until it goes out!  I know the problem is not the battery.  Any suggestions on what to do with it or a place to locate handsets that can be purchased for replacement?
  • atena_1991 Jan 28, 2009
    ive got the same prob.
    the keys are hard topress...especially specific ones...it feels as if it doesnt make contact as easy anymore to the interior
Try spraying it with canned air in and out
Posted on Feb 02, 2008
SOURCE:
DECT 6.0 cordless. Why won't it register the handset when placed on the base?
This could be several things.... the simplest is that a weak
handset battery can interfere with registration. Or,
does the handset display say "Connecting..." or
"Searching...." or "Out of Range / no power at base ..." ??
In these cases the handset is registered to another base and
must be de-registered before it can be registered again.
To deregister the handset:
Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say:
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..." and it should be ready to
register.
Dec 28, 2015 | Uniden Lands Phones
HandsetS #2 and #3 work properly. Handset #1 has a display screen with correct datet and time -- but no dial tone, How can I fix this?
This sounds like Handset #1 has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
1. Press and hold the [END] and [ # ] keys at the same time,
press [SELECT]
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go.
Nov 26, 2015 | Uniden DECT 6.0 Cordless Telephone...
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
I need to format the memory stick for my cell phone sony Ericsson
For your to format the memory stick of your sonyericsson handset, all you need to do is...
From homescreen, press menu>ORGANIZER>FILEMANAGER>press OPTIONS>SELECT MEMORY STATUS>SELECT MEMORY CARD>PRESS OPTIONS> now SELECT FORMAT MEMORY CARD and PRESS YES.. it will ask for a PHONE LOCK CODE, by default "0000" is the code for SONYERICSSON HANDSET.
OR, once you inserted the A NEW MEMORY STICK, it will immediately format it.
DON'T FORGET TO CLICK ON 4 THUMBS UP! Thanks!
Apr 11, 2011 | Cell Phones
I have a TRU9466 with 10 handsets. 3 of these hand sets have quit working. I have the correct replacements but the base will not accept any more units. (limit 10). Hence the issue, since the original HS...
As far as I know you can't deregister all of the handsets at once. However, if you know the handset numbers of your good handsets, you can exclude them and deregister the others one at a time. Press and hold Call End and # for more than 5 seconds on a working handset. Select DEREGISTER HS and press the OK soft key. Scroll down to select a handset number when you see the Which HS? prompt. Select Yes and press the OK soft key. Repeat the Yes and OK at the "Are you sure?" prompt. Press Call End. Press Menu and select Deregistration. Press the OK soft key. Then select Yes and press the OK soft key when you get another "Are you sure?" prompt. This is shown on page 61 of the manual. You can find the manual here: http://www.telecomuserguides.com/manuals/filesupload/Uniden/5_8GHz_Digital/TRU9466om.pdf .
I hope this helps.
(Since the method above works for lost handsets, it should work for handsets that can not communicate with the base.)
Feb 08, 2018 | Uniden TRU9466 Cordless Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
Handheld won't communicate with the base
i have the same problem and it has happened infrequently several times. you probably have to deregister the handset and re-register it and rest the base and handheld to communicate since my model is different from yours there may be differences in how to go about it but for my model the suggestion is as follows:
go to www.uniden.com for customer support here is a direct link to some frequentlt asked questions http://www.mycusthelp.com/uniden/supportfaq.asp?sSessionID=&lstFilter_a=&lstFilter_b=&lstFilter_c=&txtCriteria=hanset+won%27t+connect+to+base&optcond=2&iStartCount=1
DCT Series Multi Handset Phone - reset to have base and handsets communicate
Question:
I have a DCT Series Multi Handset phone and one or more of the handsets is not working, what should I do?
Answer:
Try resetting the phone system by using the following steps:
1) Enter the "System Reset" menu, then "Deregister HS" submenu.
2) Press volume/up or down arrow keys to select the handset ID to be de-registered from the list, then press the OK soft key.
3) Press the OK soft key. You will hear a confirmation tone. When de-registration is complete, "Deregistration Complete" appears.
4) After de-registering the handset, move to "Replacing the Base Setting" below. When you go through the deregister procedure if you get "out of range", That is okay. Go ahead and go to the next step.
1) Enter the "System Reset" menu, then "Replacing Base" submenu. "Do you want to replace Base?" appears.
2) Press the OK soft key. You will hear a conformation tone. The base information will be deleted. When replacing the base is complete, "Please Register" appears, register the handset to the new base.
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
To resolve out of range follow the below steps.
Press and hold the end key.
Press and hold the # key.
Release the keys and select replacing base and press select.
You will see Replace base?
Select Yes and press select.
Now place the handset on the base and it should register to the base and allow for calls to be made.
Jan 23, 2008 | Uniden CXAI5198 Corded Phone
Handset unit keys sticking really bad
I have the kx-tg2248s panasonic phone and my keys stick also. I emailed Panasonic for a solution and they suggested I mail it to a service center for repair. But I don't know what I would do without a phone in the meantime. Can anybody help? It would be greatly appreciated!
Apr 10, 2007 | Panasonic KX-TG2336S Cordless Phone
Panasonic GigaRange KX-TG5432 Cordless Phone Logo
101 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
