Question about Bunn Pour-O-Matic VPR
Bunn 33200.0015 vpr-2gd instruction manual - Bunn Pour-O-Matic VPR
  • 60 Answers
SOURCE: Bunn VPR 04276-0003
There is a thermostat underneath the top of the machine. There are a couple of little screws that you need to undo then you will see a little dial or even a little T on top of a metal box or circuit board. I recommend that you unplug the machine before opening it up. Then just turn the thermostat down - usually counter clockwise. Turn it just a little and put the top back on the machine and let it heat up.
Posted on Jul 18, 2008
mgprice
  • 744 Answers
SOURCE: WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Posted on Jul 14, 2009
  • 454 Answers
SOURCE: water not hot enough on bunn vpr
Make sure vacation switch is turned on (preheats water).
See manual here:
http://www.bunnomatic.com/pdfs/retail/usecare/41756.0000_STX_NBX_U_C_English.pdf
Posted on Dec 22, 2009
pappapumpdaf
  • 635 Answers
SOURCE: BUNN VPR commercial coffee pot, not flowing in a
Your spray head has 5 to 6 little holes depending on the model and year, and it looks like you have scale, calcium or lime blocking them.
Since your model is a VPR pour model, you will have less trouble cleaning it with white vinegar than the permanent water connection type. I use a gallon of vinegar and filters for this.
Parts needed:
2 Clean, Rinsed Empty coffee cans
1 Gallon of White vinegar
5 coffee filters
1 Toothbrush, preferrably angled head
Start with your Bunn turned off and place an empty full size coffee can under the pour spout. Now place a filter in the brew basket to catch any fine particles you don't want poured back in the resevoir and heater. You will need to change this filter a few times as the trash starts coming out of your spout.
With the coffee can, brew basket, and a fresh empty filter in place you want to start pouring the vinegar in the tank while catching the water with the coffee can. As it fills with water you will need to dump the can down the drain until the full gallon of vinegar has been poured in the Bunn. Allow the excess water to finish flowing out into the coffee can making sure to leave half the water in the can to pour back into the coffee maker.
By now your tank should be filled with mostly white vinegar, and your coffee can should be at least half full of vinegar as well.
Now you can turn on the lower pot warmer to keep the solution hot and plug your Bunn into the outlet.
Allow 8 to 10 minutes for the heater to heat up and pour the half full coffee can of vinegar into the fill area. Allow the cycle to complete and replace the filter as needed, or if flow begins to slow down.
If your heads are clogged, use the toothbrush to clear the holes as the vinegar is flowing until you see all holes flowing vinegar.
Chunks of trash will dislodge in your heater tank and flow to your spray head, so keep that toothbrush ready.
Do this at least 5 times, then allow the Coffee maker to sit 30 minutes with the heater on to finish dissolving the lime and calcium deposits in the tank.
After 30 minutes start flushing the system with clean water to rinse out all of the vinegar, or until you can no longer smell vinegar in the coffee can.
Good Luck!
Posted on Mar 11, 2010
pappapumpdaf
  • 635 Answers
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
My bunn vpr coffee maker is overflowing
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Oct 15, 2011 | Bunn VPR Coffee Maker
How do I empty the water from the resivour on VPR Model??
Aug 18, 2011 | Bunn VPR Coffee Maker
Bunn Coffee Maker VPR - should we put vinegar in the reservoir and run it though - of should we just put a little vinegar in with some water? We ordered a de-liming spring tool and we will use it when we...
Aug 16, 2011 | Bunn VPR Coffee Maker
Bunn vpr, does not brew, cleaned outlet tube, unit heats up, only 3 drops comes out
Jul 27, 2011 | Bunn VPR Coffee Maker
The nurses use the Bunn VPR 2 burner coffee maker. They have succeeded in having horrible hard water residue all around the outside of the pour area. Vinegar doesn't seem to clean it off. What would...
This can be solved by running vinegar and water through unit and here is more information.
Jun 16, 2011 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Help, My comericial coffee machine is making 2 pots
Hello. I do not see a VPR manual with automatic functions, so your unit is not a VPR. Either way, it sounds like you have a scale build up on your level probe, causing the machine to over brew, until it can "see" the water again. This would require taking the top off, locating the probe, unplug please, remove by pulling out, annd cleaning the part that sits in the water. The other thing is you accidentally changed the time setting, here is a link to the manual,
http://www.bunn.com/pdfs/commercial/manuals/10179.0000.pdf
use the instructions to reset the whole time cycle on page 6, setting batch size. Then lock the timer to prevent future mishaps.If this is not your manual, but you have a Bunn unit, go to www.bunnomatic.com, and you can find the manuals to the left side of the screen.
Hope that helps, and thank you.
Apr 05, 2009 | Bunn VPR Coffee Maker
How to prep to brew good coffee
Hello, that sounds fairly good, as you describe it. Here is a link to your units manual:
http://www.bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
go to the bottom of the page, and select the operation manual for a VPR. It is advisable to let the unit sit for approx. 20 minutes after filling, cold water works best, and you need to make sure that you pour the water in before you plug it in, as the heat circuit is always on, whether water is in it or not, including if all the water has evaporated. The manual for the unit should answer your questions.
Mar 08, 2009 | Bunn VPR Coffee Maker
BUNN VPR Overheating
Thermostat is either bad or your heating element is bad. Check both and also check for calcium and lime build up
Feb 20, 2009 | Bunn VPR Coffee Maker
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Bunn Pour-O-Matic  VPR Logo
238 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
