No support for onboard graphics for demension 2350 installing win 7
  • rwsibson May 15, 2009
    thanks i figured dat just needed confirmation before i installed the RC
    version PRES Building a new box of the x58 class when thats done i will look at install on new machine
  • Thomas F. Schneider May 11, 2010
    I doubt that one will ever be written for onboard graphics of a older computer hardware set. You may purchase a stand alone video card which has a driver written for windows 7, if you can find one. .
  • 3,267 Answers
Depending on your RAM capacity which is max. 1 GB I doubt whether your integrated graphics will support Win7. Try installing WINXP or VISTA(doubtful) as OS. Else go for a graphics card with inbuilt memory if you want to install Win7.............sodeep
Posted on May 08, 2009
How do you enable onboard video card in bios
Here's what others have tried.
I like the jumper and cmos and enable/disable portions
avatar-default.png Posted bylesleymillar on 11 Oct 2009 8:00 AM Just fitted a new PCI graphics card (Radeon 9200) in my 4 year old Dimension 2400. The only way I can get it to work is to have both it and the on-board graphics chip running together - done this by selecting the Radeon as the default display and by not having the Windows desktop run over onto the Intel display. Problem: If I disable the on-board graphics chip as per the fitting instructions and then set my Bios to auto select, the computer boots and is active but all I get is a blank screen regardless of which output the monitor is connected to. Also, as I have the Radeon as the default display in Windows I don't see anything (no Dell boot screen, etc) when I switch my machine on until Windows log on screen as I have to have the Bios set to 'On-board' in the graphics option otherwise the aforementioned problem persists. Has anyone else encountered this problem, and if yes, has anyone managed to overcome it i.e. successfully disabled the on-board chip? Unfortunately there is no Bios upgrade from Dell that allows a user to select either auto, on-board AND PCI - the last one being ideal it would seem!
{count}" data-configuration="Format=%3Cspan%20class%3D%22count%22%3E%3Cspan%20class%3D%22icon%22%3E%3C%2Fspan%3E%7Bcount%7D%3C%2Fspan%3E">0
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 4:58 PMI just configured a 2350 with a PCI card (Sparkle 8400GS), and I left the BIOS setting at auto-select. (I could find no way to disable the onboard graphics.)
    I found that if Windows installed a driver for the onboard graphics before the PCI video, the onboard graphics were used for the default monitor. Thus, I got no image from the PCI video. I connected a second cable to a spare DSUB port on the monitor to the onboard graphics and switched inputs until I got video. Then I downloaded the appropriate video driver for the onboard graphics, installed, and rebooted. Upon reboot, I switched the default monitor from the onboard graphics to the PCI video, after which I could remove the second video cable.
    Hope that helps!
  • 4tjv4usnef6m.jpg-32x32.jpg?m=634535492957260780 Posted byJackShack on 11 Oct 2009 6:32 PMSome additional information that may be helpful:
    1. The Dimension 2400 uses an on-board AGP graphics chip that cannot be disabled in hardware. It shares the interrupt for the first PCI slot which can give you trouble if you decide to place your add-on PCI graphics card in slot 1. My own add-on card wound up in slot 3, so it might be helpful to switch to another slot before giving up.
    2. If you do have your card in slot 1, try resetting the NVRAM (CMOS) by removing the battery for about five minutes. You can find instructions for that here: Dimension 2400 Service Manual. Look in the section on Removing and Installing Parts, Battery. While the battery is out and everything still unplugged, push the power button and hold it in for about fifteen seconds to ensure the discharge of any storage elements. When you put the battery back in its holder and fire everything up again, the computer will take a new inventory of its devices and will sometimes finally find the PCI video card.
    3. This next you've probably seen, but it bears repeating: Before attempting to install the new card, go to the Device Manager, Display Devices, and find the Intel Graphics Adapter. Double click it to bring up its properties, go to the bottom of the little window to Device Usage, and click the small arrow on the right to get the menu. Select "Do Not Use This Device - Disable". This will disable the onboard driver and cause the computer to load the standard VGA driver that works with all the video cards. Sometimes the reason you see nothing on the add-on card is that Windows is still trying to use the driver for its previous video adapter which is incompatible with the new card.
    Dell Forum member since 2005
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 7:40 PMIt might help to disable the onboard video in Vista, as ATI drivers can clash with it and cause BSODs. Under XP it'll co-exist.
    There is a jumper on the mainboard for clearing the CMOS. It is marked as such, and the manual will point it out.
    The default Windows driver for the add-on card will work, but without acceleration and with a very low resolution. Also, if Windows installs the driver for the onboard graphics first, it will mark the onboard graphics as the primary display.
  • 4tjv4usnef6m.jpg-32x32.jpg?m=634535492957260780 Posted byJackShack on 11 Oct 2009 9:10 PMYes, I neglected to mention that if you get the card to work in the VGA mode you should be able to install the specific driver for the card. In the past I have recommended that no attempt be made to load the driver for the card until a VGA screen can be displayed.
    Granted there is usually no conflict if the onboard driver is left in place; the problem arises when the BIOS sort of recognizes the new card but for some reason Windows fails to find a driver for it. In this situation you get video from neither the onboard port or the PCI video card port. This seems to happen a lot if the card is installed into slot 1. In the past I've corresponded with folks who seem to be able to get the card to work only by using the Windows multi-monitor capability; extending the screen onto the video card. The only irritation with this is that you get no video until Windows loads, so if you want to see the system setup screen you need to switch ports.
    Naturally I realize that a jumper is there and is supposed to work, but removing the back-up cell makes certain that the NVRAM will be cleared.
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 10:40 PMThe jumper definitely works, as I used it last week several times in dealing with a recalcitrant 2350.
    Windows should find a driver for any VGA-compatible card; it'll be a default VGA driver. However, if Windows can find the driver for the onboard video, it will use that as the primary video, regardless if they are connected or not, and the user will get no video from the PCI card. I had this problem with the 2350, and had to temporarily install a VGA cable to connect the onboard video; after installing the drivers for the PCI card, I'd switch the primary monitor to it and all would be fine.
    When I installed Vista on the 2350, I experienced BSODs on startup until I disabled the onboard video. I am not sure if this happens with nVidia cards as well as ATI ones.
    I tried two cards with the 2350: an expensive HIS 4350 ATI and a much cheaper Sparkle 8400GS. The 4350 worked, but did not accelerate video playback (ATI said they did not support it over the PCI bus), so I RMA'ed it. The 8400GS installed without incident and worked perfectly and accelerates both standard and high-def video. Both cards were installed in slot 3.
Jun 01, 2014 | Dell Dimension 2400 PC Desktop
My gf9400 gt 1gb shows blue screen, until booting it works but while loading win 7 it crash dump blue screen appears every time???? but after plug out graphic card and plug in onboard vga works fine what...
Hello bsod often means you have a driver problem, or a graphic card problem.
The graphic card could have a defect, this can cause the blue screen.
Try also to check the device manager, for any other drivers missing.
Try first to download and install the newest driver from nvidia:
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.07-whql-driver.html
This is the 64 bit driver.
The 32 bit is here:
http://www.nvidia.com/object/win8-win7-winvista-32bit-314.07-whql-driver.html
If i am wrong by my selection, choose another here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Or use Automatically find drivers for my NVIDIA products, by installing a small bit of software.
If the driver update does not help, the graphic card must be renewed.
My advice is to uninstall ALL the old nvidia software, before you install the new.
Are the onboard graphic nvidia ???
This can sometimes create a conflict, when the graphic card brand are the same.
Try to disable the onboard graphic, in the device manager.
Good luck
Mar 05, 2013 | InnoVISION Multimedia Technologies Inno3D...
Sims 3 has stopped working
Hi, What OS are you running? win 7 , XP? If win 7 right and give admin rights.
I had a similar problem but seems that Sims 3 needs a good graphics card. I was using my onboard graphics. I put in a graphics card that I had, 1 gig Geforce 9800. Now sims 3 is working great. I hope this helps
Dec 22, 2012 | Electronic Arts The Sims 3
Need graphics driver for dell demension 2350
http://dell.driversdown.com/dell-drivers-list/s_613_1.shtml and scroll down to the list.
Jul 27, 2012 | Dell Dimension 2350 PC Desktop
Function for system restore dell demension 2350
please tell me which windows you are using on your dell system?
on xp> start>all program> acc> system tools> system restore> create a restore point >next > win 7 > windows key + pause brake key> system protection>
May 08, 2012 | Dell Computers & Internet
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
Is lexmark 2350 all in one printer compatible with windows 7
I'm sorry, but the Lexmark 2350 is not compatible with Windows 7.
I checked some driver links, it Lexmark released some drivers for the supported operating systems like: Windows 2000/2003, Win XP, and Win Vista 32-bit and 64-bit OS.
If Windows 7 is supported, Lexmark will surely release a driver for this OS.
Thank you!
Jun 12, 2010 | Lexmark X2350 All-In-One InkJet Printer
I have a Dell Demension 2350 tower stuck in DOS safe mode.
restart the system by pressing the power button for 5 to 7 sec and hit the del button to enter the setup and load default setup and run an dell diagonastics
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
Display Problems
enable your onboard graphics and plug your monitor into the onboard. start up your pc and install any needed drivers for the secondary graphics card. right click on your desktop and go to your display properties you should see a faded out screen that has a 2 and a lit screen that has a 1 right click on the faded screen and check enabled then move your monitor cable over to the new vid card right click on the lit 1 and disable it making 2 your primary.
Aug 20, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
