Question about LG LMHM2017ST Microwave Oven
Oven will not shut off. Must unplug it. - LG LMHM2017ST Microwave Oven
  • 1 more comment
  • waseem Nov 27, 2013
    Hi Steve olson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    if you plug it its go run from it self and any mode run its microwav or combi mod or what
  • mikadot
    mikadot Nov 27, 2013
    I would hit the relay on the circuit board firmly to release where it spot welded itself
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven wil not shut off you can hear the
2 things come to mind, 1)check the door limit switches. also make sure the switches are switching at the same time. Or very possible to board is faulty. All the signals and commands come from the board. Electronic control goes faulty and things wont switcjh off.
Aug 09, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE Microwave Oven would not shut off even when the door was opened. We unplugged it and plugged it in later and now it seems to be OK. What happened?
Hi, the contacts in the micro switch or relay proberbly fused together. Do not open door if is still on unless you want to cook yourself
Aug 04, 2009 | Microwave Ovens
Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
May 25, 2009 | Panasonic NN-S592 Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
LG LMHM2017ST Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
