Question about Refrigerators
My American Style Whirlpool fridge freezer S20D RSB33-A/G serial number 8586 15815010 has topped making ice and the ice making system is still set to make some. I know I need a new water filter but cannot see how this should compromise making ice
    President:
  • 1,197 Answers
Is the metal arm sticking out the side of it down?
If is is then it could be the little motor. You can take the cover off and turn the white plastic cog by hand and test the rest of the system. (you might have to unscrew the cog 1st).
The metal arm sticks out the right hand side of the unit, it is there to stop and start it.
You will need to undo the screw in the middle of the cog and then turn it clockwise.
2 full revolutions is what it does each time it makes ice.
If you have a multi meter you could test to see if you are getting power to the motor, but.... be very carefull if you are going to take it apart. Some of these 'spring' apart and bits fly everywhere when you open then...lol
if it doesnt help... check the cam timer  that runs the ice maker....
thank you have a nice day
Posted on May 08, 2009
  • SAM JAYANTH CHANDRASEKAR
    hi this is iversh again.....
     if that doesnt solve ur problem..... then u can be pretty assured that its ur water filter...... that said... u dont really have to replace it ... the reason why its the water filter is because its frozen... and it has certainly blocked the cooling vent....turn the fridge off and take a hair dryer and
    hold it the direction of the tube and warm it up and melt the ice out
    and then make sure the Infra red device is set to on and the fridge is on and give it 24 hours and you will have ice again ,,,,,  if you replace the filter... run a couple gal water though it to get all the
    air out and you wont have this problem again
    hope this answerd ur query
    thank you
    have a nice day
Hi I have a whirlpool s20d rsb33-a/g american fridge freezer. the centre panel where the two doors meet is red hot, the freezer alarm keeps going of. and some times there is a clicking noise. can any
Your compressor is clearly overheating when this happens. Cause can be lack of airflow at condenser fan,defective fan and/or defective compressor start/run components. The compressor will also cause these symtoms when the start relay and run or start capacitor become defective. I don't recommend running refrigerator under these conditions as this can cause internal overload on compressor to weaken. Thanks, Sea Breeze
Feb 17, 2012 | Refrigerators
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I am trying to turn the whirlpool space 4 american style fridge freezer on. the fridge seems to be fine, but the freezer side temp display is winking and the temp control is not responding and the warning...
You have a common fault with the electronics.
Check on a large auction site for a repair kit.
Item number: 330363841350
It will only cost £30, better then a few hundred.
Hope this helps
Sep 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Oct 16, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
