Question about Arrow 8000 Power Shot Pro Staple & Nail Gun
Powershot stapler how do I reload the staples into the gun
  • 32 Answers
SOURCE: Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Posted on Nov 26, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
faceofftech
  • 185 Answers
SOURCE: I have a manual Craftsman stapler 68447 and an
you can try here:
http://cgi.ebay.com/NEW-ARROW-1-4-MONEL-STAPLE-504M1-/220606637809?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d2e26f1#ht_2432wt_911
I checked the crown website and it is a little bit harder to buy from them
if it works for you don't forget to rate me
thx
Posted on May 21, 2010
  • 233 Answers
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
Posted on May 27, 2010
SOURCE: I need instructions on how to refill the Arrow T50
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Posted on Mar 23, 2011
How to reload the easy shot stapler gun
While I am not familiar with your brand of gun, almost all of them load in a similar manner!!!!!
At the bottom REAR of the gun there is usually a couple of small tabs [connected together, but one on each side of the stapler body].
With my old Bosch T five tacker and my Swingline machine i push inward toward the front and simultaneously downward releasing th catch and then pull backward on the tab TO OPEN THE MAGAZINE CHAMBER>
Jan 09, 2015 | Tools & Hardware - Others
No instructions came with the stapler and the . I can't get it open to install staples! I need this now. You start a project and can't get what you need! I was expecting more from a product...
Open the PowerShot staple gun staple chamber. This is found on the front of the staple gun. There is a small metal area on the bottom. Pull down on this and the interior of the staple chamber is revealed.
  • Remove any existing staples that may be in the chamber. These can be pried out with your fingernail, or you can turn the staple gun upside down and gently shake the staples loose.
  • Slide a new row of approved staples into the PowerShot staple gun. These need to be slid in from the base of the staple gun (where you pulled the cover of the chamber off).
  • Close the cover to the PowerShot staple gun's staple chamber and you are ready to use your staple gun on the next household project.
  • May 07, 2011 | Powershot Tool Company Tools & Hardware -...
    WHERE do I open it to refill it??
    Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
    NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
    Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
    What size staples does the B&G Powershot staple gun use? I bought a refill pack 3/8" & 5/16" long. They fit but the shank when pulled out and loaded with staples won't close. Thank you. Julia Carr
    Hi Julia,
    You have the right size staples. The problem is the length of the refills. Some staplers can't accommodate a full length clip.
    Break the staple refill clip in half, then insert it. The shank will be able to close and latch that way.
    Best regards
    Mike
    Dec 06, 2009 | Black & Decker 5700 Powershot Forward...
    Loading staples
    Hi Sharon. It is absolutely essential that you get the staples designed for this stapler. These are Powershot 5700 staples.
    please mark this answer as a fixya! thanks.
    Mar 12, 2009 | Black & Decker 5700 Powershot Forward...
    Can't load the stapler
    check those staples or take to home store where you and i am sure they will help you figure it out
    Nov 20, 2008 | Powershot Tool Company Cobra 8000 Forward...
    Refilling the staple gun
    Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
    I need blueprints for my black and deaker staple gun
    You can find and download the product manual here in pdf. If this is not what you are asking for please let me know in further detail what exactly you are looking for.
    Jul 02, 2008 | Black & Decker 5700 Powershot Forward...
    Arrow 8000 Power Shot Pro Staple & Nail Gun Logo
    20 people viewed this question
    Top Arrow Tools & Hardware - Others Experts
    JOHN LAPIER
    Paul Sikkema
    Paul Sikkema
    Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
