Question about Motorola Radio Communications
Interference eliminator codes
Turn off code
  • Motorola Master
  • 1,654 Answers
Http://shop.giantintl.com/Manuals.asp?offset=30
Posted on Dec 17, 2015
  • 3 Answers
SOURCE: Pair of radios won't talk to each other
Have you checked the QT filter? The T5950 have an addtional interference filter called the QT filter. It filters out other radios and allows Motorola radios to speak only to other Motorola radios with the filter. Check the QT setting on both radios by pushing the menu button 6 times, the QT setting will show. If it shows a straight line on the display the filter is not on. Now push the + button (beside the menu button), to turn the QT filter on (a Y will show on the screen when on) or the - button to turn it off (the line will show when filter is off). The radios have to match all channels and all filters to talk to each other.
Posted on Sep 19, 2008
driveallnigh
  • 89 Answers
SOURCE: We have 4 T8500 - only one can talk, the other 3 only recieve.
Can you tell if the radio is actually transmitting? Is there any sound on the transmitting radio or a light inditcating that it is indeed transmitting? If not maybe the PTT button is malfunctioning. Try to use a microphone plugged into the accessory jack and see if it works. Another option is if you have a radio scanner, search the frequency range while transmitting and see if you pick up that open carrier.
Posted on Feb 26, 2009
eradiostore
  • 1654 Answers
SOURCE: how to set interference eliminator code on motorola two way radio
The FV300 does not have the interference eliminator code feature. (Sorry)
Posted on Jun 30, 2009
SOURCE: how do I access the
On the fr60, press the menu button twice. This will make the smaller number in the top right of the screen blink. Use the arrow buttons to toggle the interference eliminator code for that particular channel.
Posted on Apr 25, 2012
eradiostore
  • 1654 Answers
SOURCE: Problems setting the Interference eliminator code for a Motorola MR350 Talkabout
Holding in the MENU a long press will turn the LOCK on or off. You will need the menu unlocked for the following...
However, if you press the MENU button repeatedly, not holding it in a long press, you will walk through all the menu items, and there you will see when the CODE number begin to flash. You will also see setting for other features as you walk though the menu. Refer to your manual for these settings.
http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Posted on Jul 19, 2012
What are some of the reasons my radio transmits but doesn,t receive
One possibility is the other radios in your group are operating open squelch (aka without a tone code, private line, PL, interference eliminator). If your radio has a CODE turned on, your radio will block receiving radios without the same exact code.
Best regards.
Aug 23, 2014 | Radio Communications
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Dec 14, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Motorola kem ml36100
Code 0 (zero) turns off the interference eliminator code. Your radio would be "open squelch" in radio terms. This means you can hear all the traffic on your frequency, it might be others talking, or it might be RF (radio frequency) noise from other devices.
Suggestions: You might try your radio on a different frequency to find one with less noise. You can also stop the interference by setting your code to another number other than zero. This will block out other users. They will still hear you (possibly), but you will not hear them.
Best regards.
Sep 13, 2013 | Radio Communications
I just bought it and tested on a channel and eliminator code and it worked fine. But after a while I cannot hear static when holding "mon" and cannot hear the other radio if I talk into one. This happens...
If the radios are working fine otherwise, don't worry about the monitor feature not creating white noise (static). If you are still having a problem with the radios, try setting the interference eliminator code to off (zero). And turn off any other special features to see if you can regain communications. Then slowly add the features back in as you need them. All radios must be identical in freq., code, and features.
Best regards.
Aug 19, 2013 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout t5000 sold at Costco (several years ago) with a mini T4500. An insert was included so the mini could talk to the others. It says to hold the menu button down and then select 0 for the...
Your frequency and your code are two separate settings. When you walk your way through the menu the frequency choice will come before the code choices. Frequencies will count from 1-14 or 1-22. Codes (aka interference eliminator) will have may more choices and one of them will be Zero. It appears from looking at the T4500 manual that it does not offer "code". So on this one the code is already "zero" (off). On your T5000 you should be able to navigate to the CODE using the menu button, then use your plus or minus button to get you to "zero", then press the PTT button to save your choice.
Best regards.
Our first thought when reading your dilemma is to check the Menu Lock. Holding the Menu button in for 3 seconds will lock/unlock your buttons. You should have an icon depicting a lock displayed on the screen.
Aug 17, 2013 | Motorola T5000 Two Pack 2-Way Radios with...
Best regards.
Jul 18, 2012 | Motorola Talkabout Mr350r 2 Way Radio
How do I access the interference eliminator code
Feb 22, 2011 | Motorola Talkabout FR60 (14 Channels)...
How to set interference eliminator code on motorola two way radio
Jun 30, 2009 | Motorola Talkabout T5500 (7 Channels)...
Motorola t6500
You need to set your interference eliminator code to zero, and your Qt filter to zero also. Here is a link to the owners manual: http://direct.motorola.com/ENS/T6500%20Series%20User%20Manual.pdf
What is happening is your T6500 is set to ignore radios which do not match the same code. The fact your Cobras can hear the T6500 indicates they are set with their interference eliminator turned off (aka no code).
A similar occurance will happen if the Qt filter is set to anything but zero. The Qt filter is unique to Motorola. These features are beneficial when you are in a high radio traffic area and you want to block out hearing other people. But in your situation, you are mixing radios, and the easiest way to make them match is to turn off the special features (aka set them to zero).
Oct 17, 2008 | Motorola Talkabout T6500 (7 Channels)...
Motorola t6500
Oct 17, 2008 | Motorola T6500 2 Pack Rechargeable 2-Way...
Radio Communications Logo
43 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
