Question about Nikon Coolpix 4600 Digital Camera
Nikon cool pix 400 system error 10
I get a ''system error 10'' when I turn the camera on. I changed the batteries. I took the batteries out for 24 hours to let it reset. I changed the memory card. Still I get the same error 10. This is a Nikon cool pix 4600.
SOURCE: Nikon Cool Pix 5000 will turn on
your description says will turn on..but it looks like you describe will NOT turn on.. a dead unit.. ok, i have same issue and lucky enough to have TWO of these, the second one with a very different problem. I will troubleshoot between the two and get one working, will post results back here.. preliminary web search suggests unit has a DC to DC onboard voltage converter and DOES incorporate a fuse or more.. hopefully only a fuse is blown.
Posted on Jan 09, 2008
  • 214 Answers
SOURCE: Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Posted on May 11, 2008
dlundmark
  • 797 Answers
SOURCE: I have a nikon cool pix camera that doesn't turn on
When there is nothing happening, it is hard to understand what is wrong.
Do the menus cone on or anything turn on?
If the camera comes on at all, then try setting all the menus to default.
If nothing comes on, no lights, nothing, then you are stuck.
If it will not turn on at all, I would recommend selling it at a site such as Ebay for repair parts, as is. At least you can get some money back, and buy another camera.
Also you may want to consider to call Nikon and trade-in or trade-up your camera for a re-furbished unit (a re-furbished unit will have everything just as it came from the factory. The support-repair department would be the place to get the number and information.
Posted on Oct 17, 2009
LongPockets
  • 1177 Answers
SOURCE: what do you do when
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Posted on Dec 19, 2010
  • 102366 Answers
SOURCE: I CAN'T GET PICTURES OFF
Depending on what model Coolpix you have, look for either "Copy" or "Backup" in the Setup or Playback menus. If you can't find it, please reply to this post specifying the model.
Posted on Dec 28, 2010
Message in display says that the memory card is not formatted. I Have tried repeatedly to format. The results are the same with a new memory card. I have removed the battery for 24 hrs. but the card will...
There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article fix memory card not formatted error and learn how to fix it step by step. Best regards.
Aug 25, 2011 | Nikon Coolpix 8800 Digital Camera
System error 10
Nikon support made these suggestions:
1. insert the memory card that originally came with the camera (Nikon approved card).
If that doesn't help, then:
2. remove the camera batteries. Leave the batteries out for 24 hours. then replace them
If these suggestions don't resolve your problem, they say the camera must be sent to Nikon Service because there are no "user serviceable parts on the Nikon Coolpix cameras"
Feb 28, 2011 | Nikon Coolpix 4600 Digital Camera
Nikon cool pix lens error
Fault in the system controller, failure of the auto lens mechanism, I would suggest that you must take help if the following tip does not work.
Remove battery and keep aside. Tap gently on the lens with the palm, replace battery and repeat this to switch on.
Try this out several times to see if a locked mechanism releases.
Hope this works
Aug 22, 2010 | Nikon COOLPIX L3 Digital Camera
COOLPIX L100 Digital Camera: I am using a L 100 Nikon Cool pix. I have videos s...
Hello there, for transferring media from the memory card to your computer it is much better to remove the memory card from the camera slot and use a card reader as the operating system of your computer will detect it as new media found and you can easily drag and drop the files you want to utilize and will save battery on your camera as well.
May 17, 2010 | Nikon COOLPIX L100 Digital Camera
I have a cool pix S3 serial #35106301. When I turn
I read a blog that I think was through your website. A lady names Chrusty wrote sometime in 2006 said she had the same problem only with a differentstyle camera. She said she put it in the hands of her father. He corrected it by pointing the camera toward the ceiling and pressed the on off button qnd the shutter button at the same the same time and the problem corrcted itself. I followed the instuctions and it worked. The camera is back to normal, at least it is right now. I have put your website in "My Favorites" for future reference. Thanks for being there. Sandor Magnes 06/28/09
Jun 25, 2009 | Nikon Cameras
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Help me
Try changing the batteries. I think that is how it says it needs more juice to charge the flash.
Jul 07, 2008 | Nikon Coolpix L11 Digital Camera
Nikon coolpix 4600.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon cool pix L11lens error
Remove the battery, wait a couple of minutes, replace battery. (assuming the battery is fully charged. Check there is nothing jammed in the mech. if it still stays stuck.
Dec 30, 2007 | Nikon Coolpix 5700 Digital Camera
System error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Dec 21, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
75 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
