Question about Konica Minolta Office Equipment & Supplies
How fix error code 2101 on bizhub 552 - Konica Minolta Office Equipment & Supplies
SOURCE: KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Posted on May 27, 2009
  • 25 Answers
SOURCE: ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Posted on Nov 04, 2008
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
  • 158 Answers
SOURCE: c 2101 on bizhub c451
this error code means there is charge cleaner malfunction. during the backword movement if the cleaner the home sensor was not actuated after a predetermined amount of time. to reset the error code leave the machine on and open then close the front door if the charge cleaner motor has been disabled in service mode this error code will happen at start up
Posted on Dec 12, 2009
  • 74 Answers
SOURCE: getting error code 2101 when scanning a document
Posted on Mar 27, 2010
What is error code C3102 in Konica Minolta bizhub 552 printers
Fusing roller failure to turn remove the fuser unit check orange rollers bad replace the fuser unit
May 09, 2015 | Konica Minolta Office Equipment & Supplies
C2101
C 2101 on Bizhub 600 = Charging cleaning motor error.Remove the charge coronas and clean the gears of cleaning motor and check the connector.
Jul 28, 2014 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub 600 c-2101 code
C - 2101 The lock signal of the charging cleaning motor(mounted on the charge corona assembly) is not detected when a specified period of time elapses after is starts the backward operation from rear to front.
Remove the drum unit and remove the charge corona and rotate manually the cleaning pad,eventualy remove the cleaning motor and verify the gears.
If not reseting to Open /close the frontal door,try reset:
Turn OFF the copier,keep pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message ,release the Utility key and touch the message,then turn OFF the copier.Wait 1 minutes and turn ON.GOOD LUCK!
Mar 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Black berry error code 552. White screen with
you need to connect the phone to the computer or laptop that you are using via usb cable and open teh blackberry desktop manager and go to application loader and install the OS you want and it will be up and working great again.
Dec 28, 2009 | AT&T Blackberry Curve 8300 Smartphone
C 2101 on bizhub c451
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
