Sanyo TV will not auto program the cable channels
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Posted on Mar 31, 2008
SOURCE: Sanyo Model DP42848 42 inch
I just bought the Sanyo you inquire about and am afraid of this problem. Did you fix it? How do you like your tv? Wish I could help with your issue and appreciate your time, Pogo.
Posted on Jul 03, 2008
humanman42
  • 82 Answers
SOURCE: How to program the TV to utilize cable channels
Go into the menu on your tv via built in button on the tv, or the remote. Look for something that reads "Program Mode" or "Program Channels"
Tv's have to search for channels that have a good solid frequency if they are just hooked up. newer tvs do it automatically
Posted on Dec 01, 2008
Slapnuts1975
  • 51 Answers
SOURCE: program an old sanyo tv
You need to go into the menu and set it for cable insted of air/tv. The television is only getting the 2 - 13 because on that setting, its as high as it goes.
Posted on May 20, 2009
  • 541 Answers
SOURCE: Magnavox tv has cable channels 2-13 only. Lost
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Posted on Nov 13, 2009
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
My sanyo vcr model vwm 690 won t run auto setup when connected to
the sanyo 690 is the best vcr out I have had mine for 10-12 yrs!
just make sure you are in the vcr mode and not tv or cable mode it will do everthing for you!!!!!! columbo
Mar 22, 2009 | Sanyo Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
Menu
I think, Your TV menu item to auto-program has been locked. read its user manaul to unlock it. Many companies gives such lock facility in tv to avoid miss use.
Jun 14, 2008 | Sanyo DS24425 24" TV
Can't get channels
In set-up menu,select cable then select auto-program.....T.
Dec 12, 2007 | Sanyo HT27546 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
