Question about Dell Dim.9150 Pentium D 820 Dual Core2.8GHz+19"LCD MONITOR E193FPDELL Dimension 9150 + E193FP L... PC Desktop
  • MIDDS Oct 11, 2007
    my dell computer is the main computer.iam trying to setup so my son can access the internet in his bedroom.i have plugged the router in as instructed but cant get my computer to pick up the router
  • 84 Answers
Yes your computer based on your model number should be able to support a wireless router.
Now... you did not specify if this is or is not a second computer that is trying to access the router which is hooked up to another computer and modem. If you are trying to access it you will need a wireless nic adapter installed on the Dell. To access the router. Please comment on what the case may be in your situation.
Posted on Oct 10, 2007
  • annette best Oct 12, 2007
    You have locked my rating as unhelpful. There is nothing further I can do for you at this point.
Where is the network security key
The network security key is set by the user when the home network is setup. It prevents people from stealing your wireless signal. If you have forgot it, or didn't set it up but it still is asking for one, you can unplug and hit the reset button on your router and delete the home network you have on your main computer. From there, just run the network setup wizard from the main pc and set your network security key to something you can remember as well as write it down. Then you should be set to add any other pc to your home network as long as when you try to connect, you put the correct key in.
Sep 28, 2012 | Belkin (F5D7231-4) Wireless Router
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
How do I set up a home wireless network for windows xp?
Do you have any computer connected to the router ?
If not then connect the computer to the router with the cable.
Open the setup page of the router.
Change the name of the network.
Secure the wireless network.
Try to connect to the wireless network on wireless computer.
Once you connect to the network, you will be able to go onl ine.
Click Here for more information about the routers and network
Aug 14, 2010 | Linksys Wireless-G WRT54G Router
Cant connect wirelessly as i cant locate AOSS button
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your ps3 using it.
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
1)To use this set up for the PS3 go to Settings>Network Settings> Internet Connection Setting> (Method) Custom> (Select Connection Method) Wireless- (WLAN2_bing.gif Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
Again this only works if your router has this button. and it is not found on your ps3
so you'll need to set it up differently. if your home is set up with wireless router and your computers are connected online wirelessly read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
May 18, 2010 | Sony Playstation 3 (PS3) Console
Wont connect with my computer says cant get ip address
Are you trying to connect the computer to the wireless network ?
first check the wireless settings of the router and then connect to the network.
For this you will need to open the set up page of the router .
Click Here to know more
Nov 13, 2009 | Linksys Wireless-G Broadband Router
Im a new compaq presario cq60 owner- im trying to setup wireless network at my only option in my area- have a 2wire 2701hg-b wireless router and cant get it to work internet,wireless only with...
You will need to check the wireless settings of the router.
You said that it works only with the ethernet connection but not with the wireless connection.
Check the IP address of the computer when it is connected with the cable to the router. note down the default gateway number.
Open the set up interface of your router with the Default gateway number.
once you are able to open the set up interface of your router, you will be able to change the wireless settings of the router.
after that you will need to conncet to the wireless network on your laptop.
Click Here for more Information
Oct 06, 2009 | 2wire 2700HG-B Router (2700HGB)
My router is detecting the internet but i cant get the internet on my computer. I cant connect to my router but it says that im connected with limited access. I have it hooked up through the router with a...
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing or in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Apr 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Cannot setup home wireless network between computers
Since all computers are online, you do not need to change any setting on the router for the computers to share file or resources.
If you are using Windows XP - try this link:
For Vista:
I hope that helps!
Good luck and have a nice say!
Dec 02, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless linksys
If the setup CD is not working fine for you , It will be better for you to call the Linksys tech support and they can walk you through wtih the process on how to manually configure the router and set it up as a Home network, this is the Linksys phone number 800-3267114...
Hope that helps.........
Aug 11, 2008 | Linksys Wireless-N WRT150N Router
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Computers & Internet Logo
83 people viewed this question
Alun Cox
