Question about Kenmore Washing Machines
When was my 110 C28932790 90 Plus Series Washer made
Maytag317
  • 1136 Answers
SOURCE: kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 14, 2009
  • 1937 Answers
SOURCE: What is the capacity of the Kenmore Model 110
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Many of the Sears parts sites for washers have a section where you can see PDF versions of their manuals. Look to the right of the main sub-components list and you may see it.
Posted on Oct 17, 2009
JULIANFIX
  • 975 Answers
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Posted on Oct 26, 2009
mreid542
  • 166 Answers
SOURCE: Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Posted on Jun 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore 70 series washer 110 22702100
3.2 cu Ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
How many gallons of water does a Kenmore series 80 model 110 extra capacity plus washing machine hold at max and at 1/2 max
The Series 80 washer has a max capacity of 20 gallons. At the lowest water level setting you would have between 14.5 and 15 gallons.
Dec 23, 2014 | Kenmore Washing Machines
Should I buy a new washer? I have a great Kenmore, Heavy Duty, 70 Series, model 110, serial number C83193200. Yes, it was made in 1983 and now leaks water from the bottom front onto the floor.
It could be a dry rot hose or the pump could be leaking might be an easy fix it depends whether you want to repair it or spend allot of money on a new dryer are u pretty handy i could assist you on how to fix it .
Nov 24, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series washer 110 22702100
3.2 cu Ft
May 03, 2009 | Kenmore Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
Mar 12, 2009 | Kenmore Washing Machines
Kenmore 60 series 110 model wont agitate or spin,hear motor
Likely the drive belt/coupling or transmission has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
