Question about Hunter Ceiling Fan Remote Receiver 85112-01
Part 85112-04number need a replacement part for remote on fan
I have a ceiling fan that is not responding to the remote. I put new batteries in the remote and remote is on but not talking to the fan. The model number UC7087T
There is a sensor in the fan that needs to be replaced.Go to the website of the particular brand of fan you have... there is a troubleshooting guide (should be) that will help you pinpoint what you need to replace.
(I replaced both mine on my Hunter fans..- I have 2 remote control fans and both stopped within a few months of one another)..the website had all the info and parts I needed.. I called customer service.. had the fan model numbers handy.. they told me what I needed and sent them right out..
Oct 11, 2017 | Dryers
Will this remote take care of my ceiling fan #99500
most ceiling fans run at certain frequency around 2.5khz
i do have sound bar that can run my floor fan,
go to local hardware store with fan information and they sale most remotes there and the remotes need to be programmed most of the time depending what features you fan has.
my fans has 3 speeds, led light remote turn on and off, pull chain turn fan light off or on, forward and reverse modes
www.ask.com/mfg.name/make/model/ceiling/fan/#99500/needs/remote/replacement/
www.ceiling.fan.wow.com/mfg.name/services/parts/telephone#/
Oct 22, 2015 | Dryers
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
Remote control B-542
Peter, Home Depot carries replacement ceiling fan remotes.
Check the attached links,remote and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Hunter Ceiling Fan Remote Control Replacement Light Fan Speed...
Hampton Bay Ceiling Fan Remote Control 70830 The Home Depot
Jan 28, 2013 | Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
When I press the remote control of the Panasonic Ceiling Fan F-MY143 the fan has no respond at all. The remote control work well with others fan. The fan can't turn smoothly. Help needed.
Hi all,my Panasonic Ceiling Fan F-MY143 speed can't be control using remote controller. When remote controller is being pressed, led blinking and a beep sound can be heard. Pls help, thanks in advance.
Mar 02, 2011 | Panasonic Dryers
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
Fan won't shut off w/remote.
Does the remote have a dedicated button for off/on lights, and then off/on fan?
I assume it used to work,,???
First, regardless, replace the batteries in the remote, even if they are new.
This will do two things, reset the remote and double check the remote is powerful enough to send a strong signal.
Do you have the original set up manual for the fan?
If this is not a new install, and it simply quit, get out the manual and perform the original setup.
Sometimes there are "modes" setup on the fan by how long the wall power switch is on or off, say on for 30 seconds puts it in test mode, or on/off in less than 30 seconds puts it in operational mode.
Not knowing what you have, I cannot say that you need either a new fan or new remote, I need more information about the entire situation.
write me at service @emrrepair.com
Will
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton 52" ceiling fan Bentley
Press any of the function buttons on the remote control and see whether the red light on the remote comes on. If it does, check the dipswitch settings on both the remote control and the receiver (located in the ceiling fan). If the dipswitch settings are the same and the fan does not work, you'll need to replace the receiver. If the red light on the remote does not come on, you'll need to replace the remote control.
Oct 09, 2008 | Hampton Bay 52 In. Bentley, MICA, Oil...
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
