Question about Kenmore 82822 Electric Dryer
Kenmore He2 dryer error codes first an 88 and then F29
  • 530 Answers
SOURCE: I have the Kenmore Dryer He2 and the controls are
have you tried to unlock them? find the padlock symbol and press and hold that key next to it until the light turns off. there should be wrighting in small print that tells you how to unlock keypad. read all the lettering and let me know how it goes.
Posted on Jun 11, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
  • 56 Answers
SOURCE: Kenmore HE2 dryer will not start
the relay for the motor is probable stuck recommend service
Posted on Jun 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: 82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: can you tell me how to fix the F26 error code on
Sorry to read about your problem, I hope this helps you out.
The F26 error code indicates that the control board in the dryer detects a drive motor system failure. This could be caused by a wire harness problem, a bad drive motor or a control board failure. You did not indicate whether the dryer will restart immediately. An intermittent problem such as this could be difficult to diagnose. I recommend calling a service company to diagnose and repair this type of problem.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
My Kenmore Elite is getting to hot. It flashes f-29
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated.
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Check the above link for an detailed article above the same F29 error.
Courtesy:JSROCK - A senior expert of fixya.
Jun 10, 2010 | Kenmore Elite Oasis ST 7806 Dryer
What does it mean when is says f29 error
If you unscrew a couple nuts at the bottom front panel of washer, you can remove the bottom front panel. Taped on the inside of that panel is a book with an explanation to all your codes and how to put washer into self diagnostic test. Good luck hope it helps.
Jul 19, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 electric dryer error code f-01
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Kenmore 82822 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
