Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Bizhub c200 c-3421
Fuser
C 3201 bizhub c351
did you reset the machine after installing the different fuser a different fuser does not reset the machine requires a manual reset procedure your old one might be ok just got to hot and shut down reset the machine.
Apr 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
BIZHUB C203 FUSER
What about the fuser on a C203?
Aug 21, 2013 | Genuine Konica Minolta Konica Minolt...
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Is it possible to find a used fuser for a Bizhub c250? I only have a few months left on the lease and don't want to put out the money for a new one. Also can I install this myself or will I need a...
you can replace the inline fuse located under the communication connector. This will reset the fuser life counter. You will have to remove the fuser, remove the fuser bottom cover (one screw), cut out the fuse and solider in a new fuse. You must turn off and unplug the copier before you remove the fuser or you will cause a fuser error code.
May 12, 2010 | Konica Minolta bizhub C250 All-In-One...
What does code c-3101 mean on a bizhub c353
C3101: Fusing Pressure Roller pressure/retraction failure
hi,
open the fuser unit out of the machine and you may find that the gear which drives the fuser unit at the behind which retracts the pressure roller must have been broken. This gear is located at machine frame where the fuser sits
Jan 05, 2010 | Konica Minolta bizhub C250 All-In-One...
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 161f remove fuser
Usually a fuser unit isn't a replaceable item by the end user. It requires a service technician to repair because they are wired to a circuit board and there are glass components in them that have to be handled carefully.
Jul 03, 2008 | Konica Minolta bizhub 161f All-In-One...
Reset fuser
Unforunately once a fuser goes, you are out of luck. I don't know of any printer that will continue to work once the fuser has gone bad. It's best to keep an extra fuser handy for business-critical printers.
May 28, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
65 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
