Question about Activision Skylanders GIANTS Portal Owners Pack Xbox 360
The portal of power flashes red and makes no connection
Health lights blinking red
You say the "health lights" blinking red. If this is the power light on the front then it can blink at different rates:-
Flashing red (2 blinks) Thermal event (THERMTRIP#).
Flashing red (3 blinks) No CPU.
Flashing red (4 blinks) Crowbar.
I'm not quite sure what they mean by "Crowbar"
The user manual can be found on this link:-
http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=wsrp-resourceState%3DdocId%253Demr_na-c00448584-2%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken
whilst the link below gives you a list of the available documentation for download:-
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=501887&ac.admitted=1403517641801.876444892.492883150
Jan 18, 2014 | HP ProLiant ML110 G3 Server
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Red light flashing fs slow
Question is not clear., which red light flashing?...
Here is the link for the error light pattern, check.. its will tell you where is the problem..
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/troubleshootDisplay/?sp4ts.oid=4052955&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c02508605-12%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Sep 02, 2013 | HEWLETT-PACKARD CP1025nw Laser Printer
My new skylander characters are not reconized as being on the portal of power. Whats wrong?
1: Check the connection between the portal and the console.
2: Try different ports on the console.
3: Make sure you have the most recent updates installed.
Mar 16, 2013 | Microsoft Xbox 360 Elite Console
Setting up skylanders on ps3
I had problems sinc'ing the portal of power, I read a solution on a other site which worked for me - try this: Sinc the portal of power while in a different game.
Close Skylanders game and opened another game, I opened another game I have saved on the ps3, then followed the directions on how to sinc - I unplugged the usb then replugged it in. I opened the back of the battery compartment, turned the portal on and then turned it upside down and pressed the sinc button so the light on the side of the portal flashes really quickly. Straight away the light stopped flashing and remained on (sinc'ed). I then replaced the battery cover and closed the game and reopened Skylanders - worked great. Would recommend this method to anyone having problems. Good luck.
Mar 22, 2012 | Activision Video Game Consoles & Games
My MX8711 won't power up. The power light doesn't come on, it only flashes red 4 times and then nothing. What does the flashing red light indicate?
It could be realted to your faulty Battery.
Please remove the battery and connect the Power cable. Now switch on the laptop without battery (Make sure Power connector should be connected and switch ON).
Check whether its getting ON now or not.
Sep 25, 2010 | Gateway MX8711 Notebook
4 Flashing red lights
unplug all cables from the back of the XBOX and then plug them back on (making sure that they are connected) and then power up the 360.
from past experiences, I've only seen the 4 flashing red lights if the AV connection is not secure.
Good luck
Nov 19, 2007 | Microsoft Xbox 360 Console
Packard Bell Imedia 1402 wont boot up
you did not install the new Hdd properly, the part of the ribbon cable with colour should be by the side of the power connector and the power connector should be connected with the red cble by the side of the colour on the ribbon cable.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 03, 2007 | Computers & Internet
Activision Skylanders GIANTS Portal Owners Pack Xbox 360 Logo
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
