Question about LG WM-2277HW Front Load Washer
Lg tromm wm1832cw pf error
Pf error
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: LG Tromm wm1832cw le error
That is a water level error of some sort.
Check all of Water Valves visually.
(Pre Wash Valve, Cold Water Valve, Bleach Water Valve, Softener dispenses using Cold & Bleach Water Valve, and Hot
Water Valve.)
• Check if water taps are turned on fully.
• Check Water Valves and Water Level Sensor (Refer to PCB Connector Check)
• Check if there is any kink in inlet hoses.
• Check if inlet screens are clogged up.
• Check if water has enough pressure. If so, find out its contributors.
• Check if there is any frozen area in the unit if in cold climate. (Drain Hose, etc)
Measure the resistance of Water Valve Coil.
(It should read 1.18K ohms.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 05, 2009
SOURCE: on my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Posted on Dec 21, 2009
caroldon
  • 17130 Answers
SOURCE: lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Posted on Dec 15, 2011
tbirdfan1
  • 3051 Answers
SOURCE: LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
Lg tromm won't stay turns on
hi need more info, do you mean when its turned on at wall or on a setting, is there anything like EE or PF shown on display?
May 14, 2017 | LG Washing Machines
What is CE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
Feb 10, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM1832CW flashing IE code
Check your owner's manual for the corresponding code and problem. If unable to resolve, contact an appliance service company.
Feb 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG leaking from bottom, Not the filter clean-out.
Not necessary to blame LG, ALL of these front loaders are garbage. They were designed poorly and released too soon just to have a new gimmick.
Jan 16, 2010 | LG WM2688HWM TROMM SteamWasher
My LG front load washer won't spin! Has code OE or PF will not drain water!
Check the door lid switch. Maybe it's not closing good. Try to stick a screwdriver in the switch.
Thanks
Oct 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water Valve.)
Oct 05, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
