Question about Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
Reset button on a El8807a - Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
My Electrolux el8807a precision upright vacuum is making an awful noise when I turn it on. Any possible causes?
Your vacuum might have a full of dust reservoir. Empty it and it will become quiet again, since the vacuum motor will not be overcharged with clogged dust.
May 07, 2014 | Vacuums
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
I have an issue with an Electrolux Precision EL8802 - I can't figure out how to access the belt. I have removed the bottom dust cover and roller, but the belt isn't visible and it's not apparent how you...
There is no belt. The brush is direct drive by a seperate motor. There is a motor reset switch that you use if the brush is not turning. If that does not fix the problem, you have to take the unit in for service http://manuals.electroluxusa.com/prodinfo_pdf/Edison/86668R4en.pdf
Feb 02, 2014 | Electrolux EL8807A Precision BrushRoll...
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
The brush is not turning and a red light is on
It could be that the brush motor just needs to be reset. You should find a button near the brushroll cleaner step lever.
Nov 25, 2013 | Electrolux EL8807A Precision Brushroll...
Electrolux EL8807A Precision Brushroll Clean Bagless Upright Vacuum It has no succion with the handle
If it's an upright, the suction occurs at the base, where the rollers are. Can you explain in more detail what you are having a problem with?
Oct 18, 2013 | Vacuums
The roller wont roll
take it apart and clean the crud out of it, re-assemble and NEW drive belt while you are at it!
Sep 14, 2013 | Electrolux EL8807A Precision BrushRoll...
Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb Logo
75 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
