Question about Husky 27 in. 2-Door Base Cabinet 27BC201BP-THD
Door alignement The right door is a half an inch lower than the left door on two sets of the cabinets. Is there away to insure they align?
Kitchen cabinet doors pop open
If the hinge is out of alignment, or simply worn out, replacement may be necessary. But, if the problem is the cabinet door (warped, or enlarged screw-mount holes) a new hinge will give you the same issue you have now. A small magnetic catch may resolve your issue with less expense and no alignment needed. It involves a small (1" square) metal plate with a single screw which you attach near the the lower corner that hangs open. The complimentary magnet attaches to the door frame of the cabinet housing (inside the cabinet). Available at even small hardware stores, the catches cost about a buck, install in a minute or 2, and will discretely solve the problem shown in your video.
May 05, 2013 | Hardware & Accessories
Refrigerator door seal has gap, and the alarm keeps going off
My refrigerator as delivered had noticeable gaps in the sealing gasket. The solution is to adjust the doors to eliminate the gap. The door hinges allow for adjustment by loosening hardware, adjusting, and tightening hardware again.
Sep 09, 2012 | Samsung Refrigerators
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
I need to replace and then adjust the headlights on my 2000 Chrysler 300M. How do I replace the headlights, then adjust them.
Park your vehicle on level ground with the headlights near a garage door or wall. A good distance is 2-3 feet away from the wall or door. The location must be perfectly level and flat at a distance of 10 to 25 feet away from the door or wall.
Switch on the low headlight beams and mark the horizontal and vertical centerlines of each headlight beams on the wall using masking tape. This will mark the center of each beam with a +. The marking will tell you where exactly the headlight beams should be centered from a distance.
Move the vehicle back about 10 to 25 feet away from the garage door or the wall.
Keep the headlights on the low beam setting.
Use the markings you made on the wall or garage door to, check where the light shines and see if the centerlines still match up with the masking tape marks. If the centerlines of the two beams do not align with the tape marks, you can adjust one or both sides as needed.
Make the necessary adjustments with the lights still on while watching the light beams on the wall and your marks.
Turning the top adjusting screws in a clockwise direction will raise the beam while counterclockwise turn will lower it.
Turning the side adjuster screws will adjust the lights to the left or right.
Continue the adjustments until the center of the light beams are aligned with the tape marks. Then adjust the vertical alignment of both beams slightly below the marks on the wall. This will assure that the lights are tilted slightly downward so they won’t blind approaching motorist.
The will align bot lights, the high and low sine both are connected to the same headlight!!
Nov 18, 2009 | 2000 Chrysler 300M
Adjustment of the fresh food door.
Normal for freezer door to be slightly higher, The upper hinges can be adjusted to make minor changes and raising the front roller under the rlower door will(or lower the higher side) help align them. It is a trial and error adjustment that takes time to get the best compromise of door alignment to cabinet setting.
Eric
Oct 16, 2009 | Refrigerators
Replacing door on electric whirlpool dryer
On the bottom right and left of the dryer cabinet are 2 metal clips.
They are about 3 inches from the floor.
The door panel has corresponding slots in it for these clips to go into.
Put the clips in the door panel slot first, then align the door panel with the cabinet and close it shut. Replace 2 screws in the top right and left inside panel.
Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
Aligning front doors to same height
try adjusting the leveling legs also you can loosen the upper hinges and lift on the door with your toe the retighten
Jun 03, 2008 | Whirlpool GC5SHEXN Side by Side...
Picture out of alignment
Look in the menu for a manual alignment. From there you should be manually able to adjust each corner and overall color alignment unless other damage has occurred. Try that first.
Apr 25, 2008 | Sony KP-53HS30 53" Rear Projection...
I would open the back, behind the screen and see if the mirror mounts are damaged. if they are it could be almost impossible to alighn the set properly. good Luck
Aug 07, 2006 | Mitsubishi WT-42311 42" Rear Projection...
Husky 27 in. 2-Door Base Cabinet 27BC201BP-THD Logo
215 people viewed this question
Top Husky Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Husky Retail Supply Expert? Answer questions, earn points and help others
