Tub not spinning-everything still dripping wet
Tub not spinning -everything still dripping wet
  • Anonymous May 17, 2009
    My wash machine just hum-ms and does not spin and drain.
  • 32 Answers
Sounds like the drive coupler between the motor and the gearcase assembly is bad causing no spin.
Go for the replacement Drive Coupler Kit
For more repair help go to: RepairClinic.com
Appliance parts, help & more
Posted on May 08, 2009
My washer will spin but will the clothes will still be dripping wet.no clutch on my model and coupling ok.
Tub is not spinning fast enough for the centrifugal force to remove the moisture. check out belts for stretching and slipping.
Dec 07, 2015 | GE Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Sep 02, 2009 | Admiral AW22 Top Load Washer
Clothes are too wet after spin cycle.
There is a tube which runs from the side or bottom of the outer tub to the water level switch. Most likely, this has become a bit plugged up with (for lack of a better term) goop, right where it connects to the tub. Take it off and clean it out, or just cut off the last inch and reattach. What is happening is that the air inside is not able to escape as the water is pumped out of the tub, and the washer then thinks the tub is not empty, and thus it will not spin. After it sits awhile, enough air escapes back out the tube so that the machine knows the tub is empty, and it will allow the machine to then spin.
Aug 31, 2009 | Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
