I've had my Garmin Nuvi 350 for 2 years. It is great. Not sure what happened, but when I go to put an address in, usually it starts with the state I am in. For some reason it does not and there are no matches found for any state. It is like that option disappeared.
Your maps are either outdated or have become corrupted. Your best bet would be to update the unit. The new updates will correct your problem as well as give you the neat new item that allows the unit to actually tell you what street/road/freeway you are on. For example "Turn right on Division Street in one quarter mile off of Clinton" and it will also use a "ticker" at the top so a person can read the same directions. You should also check the other options as you can change your icon from a car to a boat to a semi to an eagle to a turkey(leg) to a herse to a jogger to even a snow shovel or a kid on an inner tube. You can add a 2GB SD card and increase the memory of your unit even more. Now the street recognition only works on units 260W and up and you can even change the voice to an elf or a ghoul and add in halloween-xmas-st patty's day and other holidays to your unit.
To do all of this you need to go to Garmin.com and locate the legacy updater on the webpage by typing in your unit and serial number on the bottom. Go here and have fun http://www8.garmin.com/support/download.jsp
