Question about Tally Line Matrix T6050 Printer
I am getting an error when i try to add the printer after installing the printer driver i am prompted for a file called t6050.gpd and it fails to pick it when i assign the folder where the drivers are sitting
  • 378 Answers
Ur driver cd is not working . try downloading the driver from the net
Posted on Jul 27, 2009
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
Heap over flow error
The "Heap Over Flow" error indicates you are basically running out of memory to store graphics commands before a command to print data is issued.
The solution is
1) Windows Printing.
A) Ensure the printers EMULATION setting matches the printer driver uses.
B) If using the T6050 printer driver ensure you have the correct lavel of firmware. The later version of printer driver need to have the latest T6050 firmware installed in the printer.
C) Consider setting the printer EMULATION to EPSON FX then install the EPSON FX100 driver on the Windows Box
Or
Install the IBM Proprinter XL24 driver on the Windows Box and set the printer EMULATION to IBM Proprinter
Using either of these two compatible drivers will 'side step' issues caused by printer firmware / drinter driver compatibility issues as it may be difficult to obtain suitable firmware or drivers due to the age of this device.
2) If you are coding the escape commands yourself you need to check these as they are incorrect if this error is seen
Oct 24, 2013 | Tally Line Matrix T6050 Printer
Difxdriverpackageinstall error 10
I am getting the error (DIFxDriverPack ageInstall Error = 10) message when trying to install my Brother MFC-J625DW printer. Is anyone else getting this? Any workarounds? I've tried re-installing the drivers and get the same error! thanks.
Aug 30, 2012 | Brother MFC 6490CW InkJet Printer
I'm having problems with opening my .gpd files and I'm wondering if you know anything about it?
If Windows is giving you trouble opening GPD files, you should either:
A) Identify a program that can open the file, or
B) Check your registry for damage caused by hidden errors.
Jun 09, 2011 | Office Equipment & Supplies
Hi everyone. Windows XP operating system, When
Clean your PC from viruses.Insert disc drive into your driver. Then installation may take place automatically.Try it.
Dec 28, 2010 | HP Office Equipment & Supplies
Connect HP 3015 all in one printer to Aspire One
Disconnect the printer from your computer. Go to Start -> Control Panel -> Printers. Right-click on the HP 3015 printer and select Delete. Confirm the deletion of the printer. If it asks about removing unused driver files, answer Yes. Reinstall the driver files using the provided setup program. Do NOT use the Add printer... dialogs. If the installation program prompts you to plug in and turn on the printer then do so, but do not do this before it prompts you. This is what generally causes the missing files problem. If it goes completely through the installation without telling you to plug in the printer (which would be unusual for HP printers), plug it in when it completes. It should automatically recognize the printer being plugged in (and turned on, if necessary) and then finalize the driver configuration.
Mar 18, 2009 | Acer Aspire One PC Notebook
Printer driver for tally t6050 vista os
if you can't find that you try with install driver
epson fx1000
many line printer running in this driver
Feb 28, 2008 | Tally Line Matrix T6050 Printer
Lexmark X5150 driver download
please try these steps
  1. Reboot the PC.
  2. Make sure the printer is selected as the default printer in the Printers folder and try to print again.
  3. If printing fails, you will need to download the printer driver again. To do this:
  4. Create a folder on your desktop and call it Lexmark.
  5. Go to our Drivers & Downloads center. Note: The name of this page/site may be slightly different in your region/country.
  6. Click Printer Driver.
  7. Select the Related Product Name from the drop-down menu.
  8. Select your Operating System from the drop-down menu.
  9. Select the desired Language from the drop-down menu.
  10. Select the latest Driver File and click on the File Name to detach it to the Lexmark folder on your desktop. Wait for the download to complete.
    Important: Make sure any copies of the driver from earlier installations are uninstalled before you install the downloaded version.
  11. Install the downloaded driver as follows:
  12. Open the Lexmark folder and double-click on the downloaded file.
  13. When the WinZip Self-Extractor screen appears, click on When done unzipping file open: <the printer file name>. (The printer file name will appear beneath this option.)
  14. Click Unzip. The installation program should autorun. Follow the on-screen prompts to install the printer.
  15. If the installation program does not autorun, locate the newly created LXK___ folder for Setup.exe and double-click on it. An installation program will run. Follow the on-screen prompts.
  16. If you are prompted to install the printer for all users, click Yes.
  17. When the installation is complete, restart the PC.
Jan 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Auto Duplexing lost with Vista drivers
The in-OS and the Full Feature release drivers for some of our products have a problem with doing duplex jobs.
Start a command window as an Administrator
Hit Windows Key (or CTRL and Esc Keys Together) Choose All ProgramsAccessories CMD Prompt – Right Click and Choose RUN AS ADMINISTRATOR When to prompt comes up click CONTINUE to allow the Command Prompt to run as an Administrator.
Stop the Spooler service - Type net stop spooler
Change current directory
Type cd %windir%\system32\spool\drivers\w32x86\3
Backup the old gpd files – Type copy hp*.gpd *.bak
Extract the files from the zip file to correct location
extract files to %windir%\system32\spool\drivers\w32x86\3 directory
Remove old BUD file Type - del HP*.bud file
Restart to spooler service - Type net start spooler
Print something duplex to test.
Thanks
Mac
Jan 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Tally Line Matrix T6050 Printer Logo
49 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
