Question about Watches
Cannot set time on digital oreex watch model 2040
I have start button 9 top right) in middle right i have the dial turner then botttom right i have reset button on left of face i have sensor top left and mode bottom left at bottom i have adjust and light...i want to set the digital time and date can anyone help thnx
SOURCE: Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Posted on May 20, 2008
SOURCE: Cannot set dials on a Paul Jardin watch which came w/out instruct
THE OTHER 3 DIALS ARE FAKE AND DON'T DO ANYTHING,IF YOU LOOK CLOSELY THEY ARE JUST MORE OR LESS TACKED IN PLACE.
Posted on May 06, 2009
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Posted on Jul 08, 2009
taran_2005
  • 10515 Answers
SOURCE: digital umbro watch purchased 2001.How to change
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
Posted on Oct 06, 2009
SOURCE: Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Posted on May 19, 2011
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
Setting Time on Police Hammerhead Watch PL 13088 JS/02
the three dials are for three different time zones, there is no minutes or seconds.
to adjust the middle dial just push the small bottom which is located on the back side of the watch
Jan 04, 2013 | Police hammerhead pl13088js-04
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    I have an old 3 button digital push button watch that I cannot set the time and date for. the top button is "ST/STP", The middle button id "LAP/RST", the bottom button is...
    hold in the mode button until it flashes.5 sec.use the right buttons to move the hr up and down. make sure it is pm or am , usually pm is shown and no am. , press mode to set mins, press rights ones to set mins, press mode. it will go thru time and date and yr. ect. last setting and mode will bring you to a set dial. not blinking. some cases rest the whole thing first by pressing all buttons at once for 5 beeps. let go and sets to defaults 1200 and 0's.
    Jun 17, 2011 | Watches
    I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
    The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
    Apr 05, 2011 | Fossil FS2919 Wrist Watch
    How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
    Setting Digital Time
    1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
      Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
      Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
      After the time is set, press the upper left button to exit the digital time setting function.
    2. Setting Analog Time
    3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
      Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
    Aug 21, 2010 | Casio Watches
    How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
    The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
    Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
    When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
    Coleman 40-408 User's Guide
    Nov 03, 2009 | Bulova Watch
    Setting digital time on elgin fh205 . need manual
    The FH205 isn't the same as a PQS Monika, there are 3 buttons, the one in the lower right just lights up the small digital display, then there are ones on the top left, and bottom left, and a dial on the right center.
    To set the digital display time, you simply change the mode to time with the bottom left button. Press and hold the top left until the seconds start to flash.
    Use the bottom right button to set the time you want, using the top left to switch from seconds, to minutes, to hours (on a 12 hour display, if you need PM, keep cycling the hours until the small PM text appears to the right of the display). After hours will be 12/24 setting, then back to normal operating mode.
    You can repeat the same steps above by switching to date view, and press-and-hold the top left button again, and set the month, day, and day-of-the-week.
    The analog time is a simple matter of pulling the crown out and turning to the appropriate time.
    Sep 27, 2009 | Watches
    Rolex 1992 daytona watch
    There should be 3 knobs on the right side of your watch. Unscrew the middle knob with the crown on it until it pops out. After it springs out, it will be in winding mode. You want to gently pull it out past this point, it will click into place and you will be able to set the time by turning the knob. After time is set just push the middle knob back in and turn clockwise unitl it is tight.
    I hope this has been helpful,
    dansfinetime ebaa
    Nov 01, 2008 | Rolex Daytona 116520 Wrist Watch
    Rolex Daytona Chromograph
    ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
    Apr 26, 2008 | Rolex Daytona 116520 Wrist Watch
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
