Question about M&S Systems DMC1CD 6-Disc CD Changer
Dmc1cd has no p ower - M&S Systems DMC1CD 6-Disc CD Changer
Disc changer is stuck. How can I remove it?
Should be a small hole by tray... Stick a paper clip in it and it should open
Oct 13, 2014 | M&S Systems DMC1CD 6-Disc CD Changer
How do I connect an auxiliary source. I cannot locate where the auxiliary input is.
Its behind the DMC1 master unit, there you'll find 2RCA Jacks for CD and 2 RCA jacks for AUX Input
Feb 16, 2012 | M&S Systems DMC1CD 6-Disc CD Changer
My toshiba p10 wont ower up at all ...NOTHING with or with out battery or cord totally dead .battery went dead when i was useing it and i tried to lug it in to the wall and it just kept on loosing ower...
Have you tried power up the Laptop without the battery installed? Remove the battery and plug in the charger, now Turn On the laptop, if there's no internal problem, it should power up which means your battery is bad, you'd need to replace it.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jan 14, 2011 | Computers & Internet
The system won't eject the CD changer.
You will need to reset your system.
Turn on the master unit and select the CD as your source. Open the door on the master unit to show all of the speaker numbers, here you will find a small pin hole next to the number 5 speaker. Use a small paper clip, unfold it and stick it into the reset hole. Hold the pin there for a minimum of 5 seconds until the clock starts to blink. Hit the time button seven times to get a solid time again. After turn on the master power and try the CD player again.
In my case the disc cartridge ejected when i was resetting the system.
Oct 26, 2010 | M&S Systems DMC1CD 6-Disc CD Changer
Correct tire air pressure
On the driver door opening decal the recommened tire pressures if not there its in the rear door opening and it's in the owers manuel under tires. The kind of whells or options need to be obserbed as the differt options may have different recomended pressures and the rear may have a different than the fornt if all the stickers are gone and the owers manuel is too 32 PSI is a safe best bet some 50 or 45 series tires need as much as 45PSI never put more pressure in the tire than what it says on the sidewall but the maximun pressure is safe but might not give the best ride quailty
Dec 05, 2009 | 2002 Cadillac Deville
Need a ower manuaal for 459rog laptop
You can obtain user/owner guide manual and technical specs of your gateway in the link below.
Please leave feedback
Thanks
http://support.gateway.com/s/Manuals/Mobile/8510056.pdf
Apr 28, 2009 | Gateway 450ROG Notebook
Carnt get ower rp614v3 router to work
Look for a factory reset button (pinhole) near the power port. Use a paper clip or something to hold it in for about 10 seconds. That might recover it.
Nov 25, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
32 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
