Question about Honeywell Heating & Cooling
Can i use a honeywell cm927 thermostat with a vaillant ecotec pro 28 boiler
zeusfaber
  • 247 Answers
SOURCE: Vaillant Ecotec combi boiler -
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Posted on Oct 07, 2008
  • 659 Answers
SOURCE: programming instructions for Vaillant boiler ecoTEC pro timer
You can probably go online to the manufacturers websit to their tech support you will probably find downloadable documents for the unit. I would look them up myself for you but you didn't list the brand or model number. Hope this answers your question.
Posted on Mar 20, 2009
  • 55 Answers
SOURCE: lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Posted on Oct 27, 2009
SOURCE: hi my vaillant eco tec pro shut down last night
Got exactly the same problem with mine. Manual says f28 = fault in gas supply, gas pressure too low. Boiler will ignite but goes out within minutes? HELP!
Posted on Jan 08, 2010
  • 104 Answers
SOURCE: vaillant eco tec pro 28
IF the weather is extremely cold, and you're getting F28, the external pipework may be blocked with ice. Warm up the external pipes (lag them if you can) - and now see if your boiler will re-ignite.
A friend fixed our condenser boiler with this tip - hope it helps you.
Posted on Jan 09, 2010
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Aug 06, 2011 | Heating & Cooling
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
Hi my vaillant eco tec pro shut down last night showing fault f.28 and will not ignite today 08/01/2010 looked out side to see the condenser pipe was frozen i defrosted the pipe but boiler still wont...
Jan 08, 2010 | KDS Valiant 6380iPTD-01 Notebook
Hi i get fault 28 on my vaillant boiler
F-28 is a common error for my vaillant. I have had this problem serviced at least 10 times (all under warranty). It is an ignition problem and can be connected to a number of things. I have had the starter electrodes cleaned only to later have them replaced(4 times). I just had the "panel" replaced yesterday (looks like a motherboard or electronics panel). This is the second time to have this replaced. All of these things can give you an F-28 error message. I have an atmotech pro and have had ongoing F-28 issues for two years. They are looking at venting/air issues as well to see if this is the problem. douglas
Dec 20, 2009 | KDS Valiant 6380iPTD-01 Notebook
Lost my user manual for the vaillant boiler ecotec plus 824 R1
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Programming instructions for Vaillant boiler ecoTEC pro timer
Mar 20, 2009 | Water Heaters
Heating & Cooling Logo
96 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
