Question about Samsung CLX 3160fn All-In-One Printer
How to clean a samsung CLX-4190 deverloper blades
Samsung CLX6210FX print heads
Dear
If you have experience on disassembly of developer and ITB then proceed else take the help of experienced person.
Check the developer cleaning blade of the toner cart. also check the drum cleaning blade and ITB cleaning blade.
If you can not disassembly you may try smart panel or smart panel to adjust altitude.
Thanks.
Jul 04, 2012 | Samsung CLX-6210FX Laser Printer
Replaced a new black toner into clx3175fw it prints lines and ghost images how can i rectify that. do i need to clean the head ? please help
Dear
The developer clean blades must be cleaned. Also the ITB cleaning blade to be cleaned. If the waste toner drive shaft broken.
Thanks.
Feb 28, 2012 | Samsung CLX-3175FW Multifunction Laser...
Printing in black is not the same shade through out the paper
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
Jan 26, 2010 | Samsung CLP 300 Laser Printer
Printing is not uniform across the page. It is heavier at each end
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Dec 23, 2009 | Samsung CLX 3160fn All-In-One Printer
CLX-3160FN has vertical streaks where it does not print
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade.Otherwise when you print the side where the blade is not properly installed will have too much color.
Aug 10, 2009 | Samsung CLX 3160fn All-In-One Printer
Black ink is so light I can barely see it. Replaced cartridge and nothing helps.
You almost certainly need to replace the drum, which runs about $95 and is guaranteed for a year. It's considered a consumable, just as the toner is, but so far I've only found them online...I've been told by Office Depot that the drums that come with the machines aren't of as good a quality (and don't last as long) as the one you'll buy after that
Aug 02, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN Vertical lines when printing black
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
Jan 14, 2009 | Samsung CLX 3160fn All-In-One Printer
My Samsung CLX-3160FN prints with the left side of the page being very light, while the right side appears normal.
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then they also needs to be cleaned.
Nov 22, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
210 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
