Question about MSI KM4M-V Motherboard
Is motherboard MSI 915G compactibale with 2gb DDR2 Ram
Is motherboard msi915g compactible with 2gb ddr2 ram?
  • 413 Answers
Yes absolutely check for the speed support in fsb
Posted on May 08, 2009
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Can my mercury motherboard PI945GCM.V1.0 support 4(2+2) gb ddr2 ram
This motherboard will support only Maximum 2GB DDR2 RAMS.
Thanks for using FixYa.
Jun 06, 2011 | Mercury P4VM800M7 Motherboard
Which type of ram is supported by msi k9mm-v motherboard
• Supports Dual DDR2 533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 2GB.
Oct 28, 2010 | MSI K9MM-V Motherboard
What is the ram supported for hp motherboard RC410-M
This Motherboard DDR2 SDRAM RAM and with a max RAM support up to 2GB.
Jun 03, 2010 | MSI RC410M-L Motherboard
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
I have ms 7142 TO INCREASE RAM
hi im josh in cebu phils.may i help you? friend sad to say there is no way you can use DDR2 because your motherboard MSI K8MM-V doesn't support DDR2 it is DDR and SDR RAM. so you better use DDR having higher freq.to upgrade your pc. thats all good luck.hope i helped you.
Feb 27, 2009 | MSI K8MM-V Motherboard
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
RAM Upgrade
let them install it for you. Go for DDR2 667. If it works, gret, if it doesn't scale down... But DDR2, and DDR 400 aren't nearly the same, they won't fit onto the same system, as their pin configs are different.
If the DDR2 doesn't fit, you'll have to go for the more expensive DDR 400.
Jan 05, 2009 | Intel Computers & Internet
Supporting the DDR2 RAM
Asus site says the motherboard supports DDR or DDR2 RAM up to a max of 2GB.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=814&modelmenu=1
Oct 21, 2008 | ASUS P5VDC-MX Motherboard
Supported ram speed for MSI 945pl-neo f
Your motherboard MSI 945pl-neo support Supports four unbuffered DIMM of 1.8 Volt DDRII SDRAM.( Supports up to 2GB memory size.
• Supports dual channel DDR2 memory architecture.
• Supports DDR2 533/400 memory interface.)
and Supports Socket 775 for Intel® P4 5XX, 6XX, P4EE, Pentium D 8XX and Celeron D processors.• Intel® 945PL/ ICH7 Chipset
for more nformation see details od your motherboard here:
http://global.msi.com.tw/index.php?func=proddesc&prod_no=227&maincat_no=1
Dec 17, 2007 | Intel Motherboard
MSI KM4M-V Motherboard Logo
100 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
