Question about Electrolux EL8807A Precision Brushroll Clean Bagless Upright Vacuum
The brush is not turning and a red light is on
    New Friend:
  • 3 Answers
It could be that the brush motor just needs to be reset. You should find a button near the brushroll cleaner step lever.
Posted on May 07, 2014
My electrolux vacuum has a red light that won't turn off and my brush roll won't work
Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
Aug 22, 2014 | Electrolux Vacuums
How to trouble shoot a brush warning light
What color light are you referring to? If it is one of the green lights that is normal for the up and down adjustments. If it is the red one that is another issue. If it is the red one, what does it do while it is on? Does it flash or is it on solid?
Jun 17, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
Dyson dc28 animal red light flashing and no suction
Clean any debris from around the brush bar. If this doesn't solve the problem you may need to take it to a qualified repair person
May 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have a Dyson DC28 animal vacuum and the beater brush will not turn. It has one flashing white light and a red flashing light.
It appears that the drive belt is not adjusted properly or has stretched. THe gunk that vacuums pick up can also affect the belt in amking them too slippery to drive. Check it out.
Mar 03, 2013 | Vacuums
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
Roller brush not working on vax air mach 6
Hi I have a vax mach air light.the brushes wont turn but the green light is on. I have checked eveything .The little button on side tube no blocks .Checked all filters.
Jul 07, 2012 | VAX Appliances Vax X3 Bagless Upright...
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Electrolux vacuum brush not turning problem: was vacuuming and rug got caught auto shut off kicked off power to brush. instead of hitting red button to restart brush I disconnected brush to vacuum some...
under the vacuum, there is a guard. remove the guard , either by 2 screws or by 2 clips. there is a belt under the guard. that is connected to the brush. the belt need to be replaced.
Jan 03, 2011 | Vacuums
When the power head is turned on it goes from green light to red light and stops. The belt is fine and there is no obstructions in the brush to stop it from turning.
this will happen only when the brush or motor does not turn the right speed
make sure to pull the end caps off the brush and clean any hairs or fibers from it
the motor you can try and turn it by hand with out the belt on and see how free it is
Oct 19, 2010 | Fantom Vacums Lighting Canister Vacuum
Riccar model rad.7 upright (radiance). roller brush won't turn and red roller brush indicator is on. roller will turn easily by hand and belt is in place. how do i fix this?
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
Feb 22, 2009 | Riccar 8955 Upright Vacuum
Electrolux EL8807A Precision Brushroll Clean Bagless Upright Vacuum Logo
120 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
