Question about Sony CDP-CX400 400-Disc CD Changer
Clean disc reader
Where is the disc reader so I may clean it?
My LG HB905sa home cinema says "no disc" whether I play bluray or DVDs. Is this fixable?
When a disc is inserted the unit reads the disc. However if dust or dirt has got onto the lens of the reader then it can't see the disc and says no disc!
Following the cleaning guide for lens cleaning in the user manual or just get a lens cleaning disc. If that doesn't work then the lens might be damaged or there is another fault on the drive.
Apr 17, 2016 | LG Audio Players & Recorders
Where is the barcode n the reader
open up the top of your machine where you put your disc, there will be a small rectangular piece of glass on the 'floor' of that opening, that your barcode reader. If you can't see it look at the barcodes on your coffee discs and 'pretend' to put in the disc wherever the barcode meets the 'floor' is where the barcode scanner is. just wipe with a damp cloth and dry. job done
Mar 28, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Cd player won't read the cd
Purchase a CD player cleansing disc which should clean the eye reader in your player- The cleansing disc comes with an alcohol wipe that that you apply before inserting the eye reader cleansing disc- Good Luck!
May 26, 2013 | 2004 Volvo XC90
My xbox 360 wont read the discs. I've cleaned the discs and have started and stopped the discs numerous times yet it keeps asking to "Open Tray" then "Close Tray" followed be...
I think that your problem isnt that the discs need cleaning but infact the disc reader or the lens needs to be cleaned. try looking at best buy for a lens cleaning kit they are pretty cheap and easy to use hope this helped and good luck.
Jan 04, 2011 | Microsoft Xbox 360 Console
How do I clean a 5 CD disc changer?
i think the concept of this type of machine is one actual disc reader (the eye needing the cleaning) and a carousel that carries discs to the play position. So a cd lens cleaner can be placed in any of the carousel parts and do as much good as in another, once should be enough.
Jan 31, 2010 | Panasonic SCAK410 5-Disc CD Changer
When i put a dvd in the dvd player it just comes on screen saying theres no disc
Try cleaning the lens with a CD/DVD cleaning kit that you can buy at a local eletronics store. If you have tech skills, open the player up and clean the glass eye reader lens with some rubbing alcohol using a Q-tip. Make sure the DVD you are using is not too scratched up. If it still don't work after you cleaned it and tried different disc then replace the optical reader drive
Nov 04, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
My disk drive is not reading the cd. I have tried blowing it out, but it just shows that it is trying to read the disk then stops thinking.
Clean smudges off of disc with microfiber cloth and a little water.  Disc will not play if heavily scratched.  Insert different discs isolate the problem.  If other discs won't play, then you optical disc reader is fu.k.d up. Get you a CD disc cleaning kit from one of those box stores and try cleaning the optical reader that way.  If that don't work, then you need IT to open this puppy up and replace the optical drive.  Do it yourself if your IT.  Order the optical drive for cheap on e-bay.
Oct 30, 2009 | Computers & Internet
The game disk could not be read.
It sounds like the disc reader is dirty, it's the little clear circle right under where a disc would go, closest to the back of the unit.
To clean, open disc cover, locate the disc reader, use a dry soft towel or some toilet paper and gently wipe it off, sometimes even a little dust can cause a problem. This should do the trick. If it doesn't, then either the disc is scratched or the Game Cube has something wrong with it.
hope this helps!
Sep 20, 2009 | Nintendo GameCube Console
Dvd player won't play disc
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
Jan 12, 2009 | Samsung DVD-V4600 DVD Player/VCR
CD-ROm for navigation is cannot be read. how do I clean the lense on reader.
It is deffinately the disc. The readers are very picky don't like scratches. You could try to clean the disc with something like the disc doctor.
Aug 13, 2008 | 2006 Dodge Charger
Sony CDP-CX400 400-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
