Question about Troy ExtendNet SX Print Server
I want to connect the print server ESI9132079.i need drivers for this print server.
    Problem Solver:
  • 6 Answers
Download and read the manual of this print server.
http://silexamerica.com/us/products/pdf/xtnd/dx-sx.pdf
You only need the actual printer drivers not the print server driver (there is no such thing for print server drivers). Once you connect to network and to Print server, you should be able to see what brand printer is connected to server such as HP, Epson, Fujixerox, Samsung, etc.
Hope this helps
Cheers
Shafie
Posted on May 08, 2009
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Apr 06, 2014 | Cnet CNP 430 (CNP430) Print Server
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Where can i download the driver for DP-301U
Print Server doesnt require driver. Connect the printer to the computer directly and check if it is printing. The drivers for the printer will be loaded and you will be able to print. Then connect the printer to Print server and you will be able to print. If it is still not printing, you have to create an LPR port for the printer driver
Aug 21, 2010 | D-Link DP 301U (DP-301U) Print Server
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
Adding a second printer to a d-link priter server
You need to connect the second printer to your print server then install the printer driver to your computers. If your print server has a printserver driver, run that so it will automatically find the new printer for you.
Jul 28, 2008 | D-Link DPR1260 Rangebooster G...
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link: http://iogear.com/support/dm/driver/GMFPSU01#display
Nov 13, 2007 | IOGear GPSU21 Print Server
Photo copier
Please confirgue the print server properly. Assign a particular ip address to it if possible. Then install the photocopier driver in computer and add the network port ip eual to the ip of print server. if it does not work install the print server driver if comes with it as a printer and assign it a ip.
Jun 19, 2007 | Toshiba (GD-1010) for e-studio25S, 16S,...
Troy ExtendNet SX Print Server Logo
229 people viewed this question
Top Troy Computers & Internet Experts
David Payne
David Payne
Are you a Troy Computer and Internet Expert? Answer questions, earn points and help others
