Question about Sony KP-65WS500 65" Rear Projection Television
Light flashes 6 times
THe lamp flashes 6 times signifying overcurrent or overvoltage. I downloaded service manual but am missing pages showing A and B boards. Have you encountered this problem before?I do have electrical experience and would like to trouble shoot it if I could.Can you help me?
  • 4,234 Answers
First of all, the 6 blinks indicate a loss of 5V on the A board. The most common cause is a defective deflection yoke. This is not a repair that should be attempted by a novice because of the procedure required to locate the defect. Please get a detailed estimate from a local servicer. An improper attempt to locate the defect can easily cause additional damage.
Sorry to be the bearer of bad news, but this is one case where a professional should be used.
Dan
Posted on May 08, 2009
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Green power light
This might be due to a problem related to the SMPS (Switched Mode Power Supply) overcurrent / overvoltage dectection circuitry. When an overcurrent or overvoltage condition is noted the SMPS's shutdown circuit will turn the tv off. An over current condition can and most usually is caused by a component overdriving which causes an increase in current requirements for the power supply which in turn causes the shut down of the TV set. In an overvoltage condition a component may not function as well as it should causing a high resistance and this hig resistance causes the voltages level to go up causing the over voltage detector to activate shutting down the TV set.
The best this to do would be to take the set to a shop if you do not have a background in electronics.
I hope this helps,
Thank you,
Shuttle83
Nov 15, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself.
this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I have seen this problem in the shop with this set. IN MY CASE it was shorted convergence chips. but it could also be any of the low voltage supplies 5,10 15,-15 lines
Oct 16, 2010 | Sony KP-53HS30 53" Rear Projection...
Green timer light blinks and then lamp light blinks.. tv will not start up.
You probably need a lamp. Check the code by holding menu and input for 5 sec. If you need a lamp the led will flash 6 times pause then flash 6 times again. The code will repeat several times if you miss the first few flashes. If the code is different, let me know what it is and I can help you. Thanks.
Jul 05, 2010 | Mitsubishi WD-65733 65" HDTV
Sony kp-51ws500 blinks 6 times
Problem on the D board, overvoltage/overcurrent protection circuit, possible part # is A1300417A , Sony also has CRT issues so be prepared to spend between $400-$550 (D board) or $800 (if D and one CRT is NG).
gd lk
Eric
Aug 18, 2009 | Sony Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
KP-51WS500 Flashing 6 Times
Well, it's DEFINITELY the High Voltage power supply is DEAD! Won't start up...or goes into OVERVOLTAGE SHUTDOWN....
Most of the time it's overvoltage problems...
The KEY to knowing which one is actually occurring is the amount of time it takes before the 6 blinks occur...
A DEAD HV circuit takes a lot of time, while the OVERVOLTAGE will take less than 40 seconds for it to register the 6 blink code....
In this case (overvoltage) replacing the HV oscillator/regulator IC is mandatory...
A dead HV circuit could be anything in the HV circuit, from the Regulator IC to the HV splitter...
It's really wiser to consult a TV technician on this....
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
2006 Chevy Equinox - Service Lamp Reset
Turn the ignition to run. Within three seconds push the gas pedal to the floor three times. Turn the key to off, and then start the car. The light should flash three times signifying that it reset. If it does not, try repeating the process, but instead of turning it to off after stepping on the pedal, just start the car.
Nov 02, 2008 | 2006 Chevrolet Equinox
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 27, 2008 | NEC VT47 Multimedia Projector
Sony KP-65WS500 65" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
