Planet audio p19746b radio shut off and only the buttons stay lit after cranking truck
Did you ever find out what was wrong?
Posted on Feb 04, 2015
Have 1998 rava 4 radio stays on with key removed can only turn off with button clock stays lit all the time also pulling fuse turns both off
Could be that the ignition switch is not turning off the trunk line that feeds the radio,etc. Needs replacement.
Sep 01, 2015 | Cars & Trucks
I have a kenwood KDC-MP245 , AM /FM/CD car audio player . When I crank up the volume the unit shuts down for a few seconds then comes back on . It continues to do this until I lower the volume , then it...
Depending on the vehicle this radio is installed in, the impedence from speaker must match the stereo as well as the resistance. If you are using factory speakers in a vehicle some are as low as 1 ohm which will cause a short in the stereo. This will cause the radio to shut off. You need to check the specs of the radio to be sure. If you need more help with this please let me know.
Sep 08, 2011 | Car Audio & Video
I just bought a car which has a Planet Audio P9725B, so i would like to save/change new radio stations on the memory, how can I do it??
To set your station preset, change to the desired station and hold the numbered preset for a few seconds and it will stay there
May 07, 2011 | Planet Audio P9725B / P9720 Car Video...
Remote wire doesnt turn off amps. and when driving stereo shuts off and comes back on, or puting truck into drive,reverse,or park,the radio shuts down. not all power the lights stay on and amps stay on i...
it sounds like you either used the wrong wire to connect the ground or the wrong wire to connect to the remote power.
for ground it should go to a clean paint free spot on the body of the car - try using a screw that is already attached to the cars chassis or a metal frame point
for the remote turn on wire try attaching it to the wire for you stereo ( it should be switched properly)
if it is doing what you are saying one of these 2 options should work
good luck!!
if you need more help write back and give me as many specific details as you can
Mar 27, 2011 | Eclipse 5506
When pushing the push to talk button either on the radio or the headset cord I get a loud beep over the speaker and the radio won't transmit. I have replaced batteries, reprogramed unit still no fix. Any...
Two thoughts, I know you've replaced the batteries, but this can be a sign of a low, bad or weak battery. You might check your charger to see that the light is coming on and staying on during charging. Also, be certain the radio is shut off during charging.
Secondly, be certain when using any audio device the radio is shut off when plugging in the audio device. And the device is designed to go with the radio you are using it with.
Troubleshooting thoughts: 1) Try a battery directly out of a working radio to see if the problem stops. If the problem persists, you have a radio or device problem. 2) Try the radio without the audio device, with a known good battery. If you still have a problem, you have a radio problem. 3) Try your audio device on a known good radio. If there is no problem, your audio accessory is okay.
Best regards.
Oct 19, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
04' Ford FreeStar - The Radio Stay On When Van Is Off
Nothing wrong with it. When you remove the key, it stays on for about 20 minutes. It gives you time to finish listening to your radio and roll up the window. Once the driver door is open, everything shuts off or if 20 minutes has passed.
Mar 28, 2009 | 2004 Ford Freestar
Power on problem for XD7500
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key on. If only one has power the radio will not work. If the red and yellow wires are switched it can also affect the way the redio operates. One is constant power for memory the other is key on power so the radio knows to shut off with the ignition key off. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Aug 02, 2007 | Dual XD-7500 CD Player
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
