Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
I dont now how is the wiring diagram of sh711aa honda rectifier
How to wire the regulator/rectifier of TMX 155 CONTACT POINT.an how many voltage is the regulator/rectifier.thanks for ur reply
Hi, Edgar for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Honda, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Philippine Electronics Forum
tmx 155 contact point wiring diagram Google Search
http://gvmtintel.us/manual-book-download/pdf-book-download/honda-tmx-155-service-manual.pdf
Honda TMX 155 2013
Jul 21, 2016 | Motorcycles
My rectifier wires are overheating and melting this happens when the bike runs for just a few seconds any answers why
check if connections are corroded. is battery ok, some earth out when need replacing. are earths ok, esp the battery to frame. is the rectifier giving out 2 positive 12v wires as it should .. 1 to battery one to system..if that dont sort it give this ago ( your need a volt meter) http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
Feb 17, 2013 | Motorcycles
2002 Honda CR 250 R wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2002 Honda CR 250 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
CR250 2002 2003 pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://owners.honda.com/assets/ownerlink/model/own_man/powersports/2007/2007_cr250r.pdf
Jul 26, 2012 | 2002 Honda CR 250 R
Hi I've just got a Honda cb250n and there now
Hi if you havent already checked the fuse at the starter solenoide 30amp check it first. Next locate the rectifier this will have 3yellow wires these come from the alternator and provide AC voltage to the rectifier which is then converted to DC voltage used for charging the battery, at the rectifier you have green wire/s this is the earth and red wire/s this is the voltage in and out, it is here at the connecting block you must inspect the condition of the wires do not unplug the block simply check for oxidiseing which is visible to the eye and is green in colour, simply twist and pull gently on each of the wires to check for conectivity, if any break off you can bypass the block by removing the wire from each end .next it is not uncommon on the old 250n for the ignition switch to become faulty, using a test light if you dont have one make one up by removing one of your indicators, the coloured wire orange or blue depending on which side you remove is the indicator live wire, at the ignition switch using your test lamp check for 12 volts by placing the coloured wire on the red ignition wire your lamp should light if you have voltage here, if you dont have power trace the wire back and look for breakages in the wire, you could also run a new wire from the battery to the switch and with this connected the switch should opperate normaly
Oct 20, 2011 | 1972 Honda CB 250
I need a copy of wiring diagram, i have a big problem on my battery,its always overcharging..last day i purchased new one , but the results is the same..what is the problem.i didnt touch the...
Well, it is not the wiring that cause the problem but your rectifier/amplifier, it is located under LH, it is faulty and need to be replaced. Cheers
Nov 17, 2010 | 2002 Honda XR 200
Hoo.cwiring diagram for 93 honda cbr900rr for the rectifier
THIS DEPENDS ON WHETHER YOUR RECTIFIER HAS 5/ OR 7 WIRES, SIMPLE ENOUGH THOUGH , YOU WILL SEE THREE YELLOW WIRES THESE WILL COME FROM THE AC SIDE OF THE GENERATOR ON THE ENGINE TO THE RECTIFIER, IT IS HERE THE AC, ALTERNATING CURRENT IS CHANGED TO DIRECT CURRENT DC IS USED FOR STARTING THE BIKE, AND PROVIDING POWER FOR LIGHTS ETC, YOU WILL THEN FIND 1 OR 2 GREENS, GREEN IS THE BIKES EARTH ON OLDER HONDAS, SO PUT THESE WIRES TO A GOOD EARTHING POINT ON THE BIKE OR WIRE INTO THE LOOM , YOU WILL TEN FIND 1 OR 2 REDS, AS RED IS THE DC OUTPUT FROM THE RECTIFIER YOU WILL NEED TO CONNECT THIS TO THE POSOTIVE+SIDE OF THE BATTERY
Sep 09, 2010 | Honda CBR 900 RR Fireblade Motorcycles
Need wiring harness diagram
Go to this site and you can download a free PDF service manual.
www.carlsalter.com/motorcycle-manuals.asp They have a single manual for a GS750. It is for a 1976. That is close enough to your '78 to still be very useable.
Can I get a “very helpful” rating on this answer?
Aug 13, 2009 | 1978 Suzuki GS 750 E
I need wiring schematic
I bought a cbr 600 , but bike came with the wirers not connected. Rectafire, was also not connected? need diagram or help really badly!!!!
Jun 26, 2009 | 1994 Honda CBR 600 F(2)R
Charping system
I would start by getting a shop manual, Get either a Honda manual or a 3rd party manual by Clymer or Haynes. The manual will have pictures/diagrams of the locations of different parts and a wiring diagram which you can use to trace all the wiring and connectors. The manual will also give instructions on how to test the regulator/rectifier/stator etc. You will also need a multimeter.
Nov 20, 2008 | 1975 Honda GL 1000 (K1)
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
340 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
