Question about Emerson EM2517 Corded Slimline Phone
M0-m9 code - Emerson EM2517 Corded Slimline Phone
I have Bulova and found on the case M0 or MO, does this mean the year 1960?
Yes, Bulova used M0 to indicate the year 1960, but the marking on the case may not necessarily match the movement. It is not uncommon to find a movement that was produced one year earlier or one year later in a case made for the model. So, although the case of your watch was produced in 1960, the movement may be from 1959 to 1961.
Apr 03, 2015 | Bulova Watch
Whats the value of bulova watch c9671206 ?
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
Jul 26, 2014 | Bulova Diamond Watches
Can't store values
You must select the memory location (M0 to M9)
To store 45 in Memory M7, type in 45, press the STOre key, then press 7.
To recall the contents of M7 press RCL 7
Apr 06, 2014 | Texas Instruments BA-II Plus Calculator
What year was the a Bulova Diver watch made with serial number: G117649, M8
M8 in the serial number of your watch signifies that it was manufactured in 1968. Here is a list of codes that are used to identify the year the watch was manufactured just in case you were curious.
A8 = 1948
A9 = 1949
L1=1951
L2=1952
L3=1953
L4=1954
L5=1955
L6=1956
L7=1957
L8=1958
L9=1959
M0=1960
M1=1961
M2=1962
M3=1963
M4=1964
M5=1965
M6=1966
M7=1967
M8=1968
M9=1969
N0=1970
N1=1971
N2=1972
N3=1973
N4=1974
N5=1975
N6=1976
N7=1977
N8=1978
N9=1979
P0=1980
P1=1981
P2=1982
P3=1983
P4=1984
P5=1985
P6=1986
P7=1987
P8=1988
P9=1989
T0=1990
T1=1991
T2=1992
T3=1993
T4=1994
T5=1995
T6=1996
T7=1997
T8=1998
T9=1999
Jul 16, 2011 | Bulova Watches
Need an instuction manual
English Spanish German French Dutch Japanese M9 Stompbox Modeler M9 Pilot's Handbook pdficon.gif pdficon.gif pdficon.gif pdficon.gif pdficon.gif pdficon.gif M13/M9/M5 Model Gallery pdficon.gif pdficon.gif pdficon.gif pdficon.gif pdficon.gif - M13/M9/M5 FX Parameters pdficon.gif - - - - - M9 Advanced Guide pdficon.gif pdficon.gif pdficon.gif - - pdficon.gif
Jun 01, 2011 | Line 6 M9 Stompbox Modeler Guitar Multi...
My Sharp 40'' LC-40E67UN has a dull and dark picture. Tried manual settings, not helpful. They have OPC automatic, not helpful.
Backlight -6, Contrast 32, Brightness 0, Color 0, Tint 0, Sharpness 0, CMS HUE = R 4,Y 1,G0,C 10,B0,M0; CMS Value R-6,Y0,G-10, C 10, B 10, M0 ColorTemp = Low, Active Contr=Off, Film On, DNR Off, OPC = Off.
Jan 29, 2010 | Sharp Aquos LC-32D40U Television
Http://www.orkut.com/Home.aspx?tab=m0
add www.orkut.com in trusted zone then set security low for trusted zone.
then resat interent explorer.
Jul 13, 2009 | Computers & Internet
P5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
Sep 10, 2008 | ASUS P5LD2-VM Motherboard
Emerson EM2517 Corded Slimline Phone Logo
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
