Question about HP w17e Monitor
My monitor hpw17e got power but goes of emediatly
While start the computer goes well after few seconds its gows off power light is green.when press power button it goes on and then off again.what to do
PaulRepair
  • 66 Answers
SOURCE: After hooking up this monitor,the 1702 goes
Hi Don,
it sounds like your monitor's Capacitors have gone bad. This is very common. It is repairable, but the caps have to be removed and new ones resoldered on.
If you have soldering skills, not too tough of a job. If not, a shop will usually charge around $100 or so. You will have to weigh the cost vs a new monitor on this one.
Here is some more info for you on the Capacitor plague, that is quite common on monitors now.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 09, 2009
Bat1956
  • 585 Answers
SOURCE: Dell E152FP monitor goes black at startup, but not permanently
My bet is that your monitor is on it's way out. If this is true, it will get worse until it gets to a point where it no longer works at all. Connecting the monitor to another computer should confirm my suspicion. The monitor has probably developed a problem with some capacitors inside. The parts are not expensive, but finding a shop to do the work at all may be a challenge. If you're handy with a soldering iron you might want to have a try at it.
Posted on Jun 13, 2009
  • 1684 Answers
SOURCE: HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 19, 2009
SOURCE: I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
Posted on Dec 09, 2009
  • 5 Answers
SOURCE: my hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Posted on Jan 13, 2010
W17e Monitor: Is there aLinux driver for the HPw17e monitor?...
Hi, unfortunately compatible driver for this flat panel monitor for Linux is not available in the HP site hence it is not available.
May 18, 2010 | HP w17e Monitor
Plug in, press power, green light flickers once per second after a while goes to once per two seconds. then on screen comes up saying " no signal". then it goes ( according to the now orange light} to...
It sounds to me like your computer is not sending a signal to the monitor. If you switch monitors (borrow one if you don't have one) and the results are the same, I would look for the problem in your computer. Assuming you never see anything on the monitor when starting up the computer, the video card is suspect.
Of course, you need to check the cable connections and see if the video card (if an add-on card) is tight in the slot in the motherboard.
Mar 23, 2010 | Gateway FPD2275W LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
HP Pavilion meets monitor
I would fathom a guess that the motherboard has been damaged, if it is the PS then you can see by taking it into a service center to have the output checked 3 v 5 v 12 volt good luck.
May 26, 2008 | HP w19 19" LCD Monitor
HP w17e Monitor Logo
44 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
