Question about Kenmore Heating & Cooling
How many btu's in a sears 580.75184 window heat/cool unit
I need to know if there are enough btu's in this unit to heat a 1200 sq ft house
SOURCE: Random "Cracking" Noise
Its refrigerant gas has leaked out so ice is forming on the evaporator which breaks and causes this cracking sound. The same is resulting in less cooling as well. Get the refrigerant gas pressure checked and fixed.
Posted on Oct 05, 2008
  • 12 Answers
SOURCE: amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Posted on Jan 31, 2009
  • 1150 Answers
SOURCE: My window Arctic King isn't removing moisture. No
I've been looking for your manual but so far, not luck. I'll keep looking.
If unit runs for long periods of time, it very well could freeze up. Unit will dehumidify any air that is blown over the cooling coil (evap).
Does your unit drip water while it is running? If not, it may be low on freon. Has it ever worked right? I am assuming it is a window unit and not a "Thru the wall" type.
The parent company is Midea-American. Their web site offer virtually nothing but sales pitches. Big waste of time. They work with Toshiba and Carrier but don't know to what extent.
I suggest running the unit one day with the damper in one position and the next day run it in the other position and see if there is any real difference.
Hope this is of some help. Good luck and I'll keep looking.
Posted on Jun 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: 4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Posted on Jul 21, 2009
erpaalai
  • 999 Answers
SOURCE: whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Posted on Aug 15, 2009
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
Aug 05, 2011 | Danby DPAC12031 Air Conditioner
I just had 'goodman gpc1336h41ab' 13.00 seer unit installed , I have a 1250 sq. ft. home and it just doesnt seem to be cooling. The unit runs constantly. So my question is , is my unit big enough...
There are a few variables that determine the size needed to cool your home - the size of your home, type insulation, are just two. I have a 2600 sq ft home - about 1300 sq ft per floor. I choose to cool the entire second floor (bedrooms and baths) and two of the largest rooms on the first floor (kitchen & living room) via flexible ducts from an air handler installed in my attic. My house was built in 1960, and at the time had electric heat. This means it is fully insulated. I replaced all the windows with energy efficient types, and vinyl sided. I installed soffit, ridge and gable vents to keep my attic well ventilated. I can cool my house in Boston, MA to 70 degrees (when it is 85 degrees inside) with a 4 ton unit in a little over an hour with no problem (one ton of cooling is equal to about 12,000 BTUs). Your condenser should not run non-stop. If it is not cooling then it is not a thermostat problem, but could be a gas charge problem. If you haven't paid the contractor in full yet - that may be the reason why. The contractor should know how much cooling you need for the space you have and installed a properly sized unit. Make sure your air filters on the return are clean and replaced regularly. Call the contractor and explain the problem - he should be able to solve it for you very quickly.
Aug 03, 2011 | Heating & Cooling
It is 106 degrees outside, I have a a/c unit which is cooling at 75 degrees in a 1180 square foot townhouse apartment, this seems like the unit is doing all it can with the excessive heat, is it
Unfortunately, 7000 Btu's will not cool 1180 sq ft. At best, it's rated for 400 sq ft, as it's only rated as a "Room Air Conditioner". To cool 1180 square feet, you'll need at least 30,000 Btu's (like in Central Air Conditioning) or 4 more window units spread out throughout the condo. It takes more Btu's to cool, than it does to heat.
I really sorry. I wish I had better news for you. Thanks for choosing FixYa.
Aug 02, 2011 | LG Heat cool Window Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
The unit is not cooling the room. It is only comforting when you are in direct line of it.
you need to find out the size of the unit.
Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
Jun 06, 2011 | Samsung AW0603B Air Conditioner
How much area can 1hp of this brand can cool
the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
fyi - it doesn't matter what 'brand' - they all work off the same principle.
hope this helps
Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
