Question about Brother Office Equipment & Supplies
Brusbsn exe - Brother Office Equipment & Supplies
Brother DPC- 115C
It sounds like you need to update the head property...that's usually what the maintenance 7X is. These are some complicated instructions. Try to go through them and post back with a detailed description of where you get stuck (sorry, I don't have the graphics except via email) :
[ 2 ] To Update the head property information stored in the EEPROM on the main PCB:
For the MFC210C U.S.A./Canadian models, skip steps (1) through (3) below.
(1) Make sure that the machine's power cord is unplugged from an electrical outlet.
If the machine is connected to a PC, unplug the USB cable.
(2) Switch on the PC.
(3) Plug the machine's power cord into an electrical outlet.
(4) Press the Menu/Set and Black Start (Mono Start) keys. Next press the key four times to
make the machine enter the maintenance mode.
TIP: Models equipped with numerical keypads can enter the maintenance mode in the same
way as conventional models; that is, by pressing the Menu/Set, *, 2, 8, 6 and 4 keys in this
sequence.
(5) Connect the machine to the PC using the USB cable.
(6) On the PC, run the ID/head property setup utility (BrUsbsn.exe) in the folder created. The
following window appears.
(7) On the Model menu, click BH3.
6-9 Confidential
(8) In Port, select the port number assigned to the BHL2-Maintenance Printer.
To confirm the port number, follow the instructions below.
Click Start | Settings | Printers.
The Printers window appears as shown below.
Right-click the BHL2-Maintenance Printer icon.
Click Properties.
6-10 Confidential
The BHL2-Maintenance Printer Properties window appears as shown below.
Click the Ports tab.
The port number assigned to the Brother BHL2-Maitenance Printer, USB010 in this example,
is one that has been selected in Port on the BrUsbSn screen (page 6-8).
(9) In the Head Info. box on the BrUsbSn screen (page 6-8), type 12 digits (e.g., 776601D00009)
out of the 13-digit property code (enclosed with asterisks, e.g., *J776601D00009*) which is
printed on the bar code label attached to the head/carriage unit. Click the OK button.
(10) To check that the entered head property is correct (using Function code 68 in Chapter 8,
Section 8.5.16.):
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the 6 and 8 keys in this order. Then press the 2, 5, 8, 0 keys in this order.
DCP315CN/310CN/120C/115C/117C/110C
Enter 6, 8, 2, 5, 8, and 0 by using the and Set keys.*
(*To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the Set key. Repeat this operation for each
numerical code.)
The LCD shows the current head property information (12-digit code) stored in the EEPROM
on the main PCB.
(11) Check that the character string entered in step (9) is displayed in "XXXXXXXXXXXX."
If it is OK, press the Stop/Exit key.
If something other than that is displayed in XXXXXXXXXXXX, check the connection
between the PC and machine and go back to step (6).
Nov 03, 2007 | Brother DCP-110C All-In-One InkJet Printer
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Computers & Internet
I recently did a repair on windows xp and was wondering did everything go well? Here is my report: Logfile of Trend Micro HijackThis v2.0.2 Scan saved at 6:22:26 PM, on 3/23/2010 Platform: Windows XP SP3...
Apart the fact you have way too many programs on autostart, that there are still traces of the infection left and you are running a pirated OS, no.
Mar 24, 2010 | Acer Aspire 3000 Notebook
My antivirus wont run and i cant install any other antivirus
Have you tried to start the system in safe mode? F6 I think, then start in safe mode with network. then try to start your norton AV again and try to do a liveupdate, then scan your system and see if it works.. otherwise just uninstall norton, then reinstall it and run live update again and scan your system. My thought is that you have a serious virus on your sysstem.. best thing I can say is WHEN you get your antivirus to work again make a habit of scanning every file you download and from whatever site you dl from.. do NOT believe it when a window pops up and says you need to update your antivirus software.. ONLY use the liveupdate. Another POSSIBLE fix is to use the RESTORE option and try to restore to a point BEFORE you started noticing problems with your antivirus
May 23, 2009 | Microsoft Windows XP Professional With...
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
May 21, 2009 | HP Compaq Presario V3000T Notebook
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
254 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
