Swan sw2020b pause light flashing - Washing Machines
3 Suggested Answers
  • 6277 Answers
SOURCE: i have a swan sw2020b
Absolutely katelouise12 !
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 22, 2011
  • 6277 Answers
SOURCE: swan sw2020b wont spin
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
John C
Posted on Oct 08, 2011
Testimonial: "many thanks worked a treat"
Swan essentials washing machine wont start pause play button just starts flashing after a minute or so
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them
from, and they sold online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Washing Machines
I have a swan sw2020b washing machine but have no user manual. would you be able to point me in the right direction to finding one. thankyou x
John C.
Aug 22, 2011 | Washing Machines
I have a jazzy 1121 power chair and the lights on the joy stik are flashing and the chair just stoped working
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
Mar 06, 2011 | Health & Beauty
Swan Essentials dishwasher in white SDW7030W instructions
My Swan Dishwasher defaults to Intensive and keeps beeping, It will not start, can anybody help me please The model number is SDW7030W. Thanks
Sep 10, 2010 | Dishwashers
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Check engin light
it is flashing the codes if you got the sequence right it is codes 12,21,55 what engine? 12 battery disconnect,21 isO2S shorted to voltage, and 55 is MIL may not come on
Mar 05, 2010 | 1995 Jeep Grand Cherokee
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
