Question about Peavey Music
I am trying to connect a computer to a peavey src 4026 to record sermons
I am trying to connect a computer to a peavey src 4026 mixer. We currently have a cd player and recorder connected but we want to start recording to the computer to be able to upload files to our website. I have no experience with a soundboard mixer but have competent with a computer. I attached a stereo jack to the computer with the RCA cable connected to the soundboard mixer to a vacant input channel port. I'm not sure where to connect the other stereo to RCA to the output on the soundboard mixer. Thank you for your help.
    Master:
  • Peavey Master
  • 923 Answers
Why not un-complicate the circuits by eliminating the soundboard first?
Posted on May 11, 2017
  • 17 Answers
SOURCE: transfer recording from technics piano model sx-pr602-m to comput
the correct way to transfer files from the piano to a computer is via the MIDI out socket on the piano ...not the jack
you may possible need a midi to usb convertor ...which readly available and cheap
Posted on Feb 02, 2009
  • 1138 Answers
SOURCE: connecting the kaoss pad 3 to my built in turn table mixer
Try connecting the main output to the input of the Kaoss and the output of the Kaoss to your amp. You will get more signal.
Posted on Aug 06, 2009
  • 1138 Answers
SOURCE: recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
Posted on Aug 28, 2009
  • 4 Answers
SOURCE: I need help with my Boss Micro BR. I want to
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Posted on Oct 13, 2009
SOURCE: Hi i have djx 750 and i have connect the master
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Posted on Dec 27, 2009
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Trying to record a mix through a peavey board. I do not get a high pitch hum until I click rec on my Mac. I am connected via usb to the mixer board. Any suggestions on what I might could try to stop this...
First, check your levels on the console. Is anything turned up high, channels, gain settings on channels? Check and see if the noise exists whith the main outputs muted or turned down. If it goes away it is a fader or gain setting on a channel. If it persists, then you have a co nection issue with the USB . Try a different cable. Make sure the Mac is on the same electrical circuit as the mixer, or if it is on battery, try adding it on the electrical circuit with the mixer. See if location of the mixer to the computer makes a difference as well. They may be too close to each other. Hopefully one of these things will fixya.
Nov 23, 2014 | Music
How connect nuendo to PV mixer?
well you will have to look in your computer, then the program, and then find audio properties and look for the peavey ASIO driver and connect.
May 29, 2014 | Peavey 32fx USB 32 Channel Mixer
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
Apr 27, 2011 | Peavey Kb 2 Keyboard Amplifier
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Electrical interference on a DELL laptop.
Try a ground lift on the audio desk Im guessin it phase issue
ground lift is a small grey or orange 2 prong mail and 3 prong female any hardware store will have them...FYI
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
Peavey SRC 4018
You can find Peavey's manuals in their archives at
http://www.peavey.com/support/searchmanuals/archived.cfm
They are grouped alphabeticaly across the top.
Go Fer' It,
FixThemAll.........
Sep 03, 2008 | Peavey 32fx USB 32 Channel Mixer
Music Logo
35 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
