Question about Citizen Watches
I can't get my watch to turn on. Do these need batteries?
My watch doesn't have power, and i can't figure how to power it back up.
  • 8,016 Answers
You have three sources of energy.
Solar/Light energy: expose the watch to direct sunlight.
Battery: replace a spent battery with a fresh one.
Kinetic or Automatic: the watch gets its energy from the movements of the arm on which it is worn. . It must not be put in some drawer and forgotten.
Posted on Nov 28, 2013
Dropped watch on floor and doesn,t work.
Simmon, Try to take the back off watch, and remove and reinstall battery. The watch battery some times looses contact when dropped or hit sharply. I have had to do this on different watches that have been dropped.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 12, 2016 | Watches
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
hi,
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
http://www.nike.com/timing/extranet/product/os_alticomp/osac_manual_eng.pdf
If it doesn't help then try another new battrey.
OK
Sep 19, 2011 | Nike Lance Armstrong Limited Edition Lance...
Hey, i got my new watch and it s totally powerless. i have sat it on the window for 3 days and still nothing can you help
1 Does it say Eco Drive on the dial? If yes go to number 2 If not it is a battery powered watch and may need a new battery. 2 Is the crown pushed in all the way? Some watches stop when the crown is pulled out. 3 If this doesn't help you have a 5 year warranty
May 24, 2011 | Citizen Silhouette EG2450 53E Watch for...
Can not turn on
Then it needs a new battery or some sort of repair. The button on the face turns the monitor on for use, if this doesn't work, then you need to replace something.
Apr 24, 2011 | Polar FS1 Unisex Heart Rate Monitor Watch
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    Oct 04, 2010 | Colibri PWS-95877-N Pocket Watch
    What size battery do I need for armitron digital sport watch 40-8117 m-690
    If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
    Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
    Swatch Irony Battery replacement will not work
    mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
    Jul 17, 2010 | Swatch Irony watch
    Have a casio g-shock GS-300. Need to turn off the hourly signal (the beep). Grateful for solution
    I have a Casio GS-300 watch. I need to change the batteries, but cannot figure out how to get the back off. Do you have any ideas as to how I can do this.
    Thank you Vanessa
    Jun 11, 2010 | Casio Watches
    Stumped
    Try to use a piece of tape to cover on the battery, this is a way to do the insulation to prevent bad contact.
    Tsai
    Jun 19, 2007 | Kenneth Cole Reaction Square Steel Case...
    Watches Logo
    101 people viewed this question
    Top Citizen Watches Experts
    Jimmy Accardi
    Ansel Alberto
    Ansel Alberto
    Are you a Citizen Watch Expert? Answer questions, earn points and help others
