Question about Air Conditioning and Heat for Acura Rdx
Compressor fuse refrigerant - Air Conditioning and Heat for Acura Rdx
No power to ac compressor
If there is no refrigerant in the system, the safety switch will not provide power to the compressor clutch. CHECK YOUR REFRIGERANT LEVEL, repair any leaks, evacuate and recharge the system, making sure to use proper refrigerant and refrigerant oil.
May 07, 2015 | 2001 Mitsubishi Eclipse
2010 hyundai sonata ac won't turn on
Check that there is 12vdc at the compressor power wire. If there's a loss of refrigerant (leak) , the compressor will not start. The refrigerant also cools and lubricate the compressor. The system is designed to protect the compressor. There is also a fuse in the fuse box to protect the cooling system, so check that too.
Aug 28, 2013 | Hyundai Heating & Cooling
AC does not work 2000 Ford windstar
first thing check AC compressor fuse.the AC compressor clutch should engage when you turn on airconditioner if AC compressor dont come on and fuse okay compressor clutch is open or low on refrigerant you need check your AC refrigerant low pressure side and high pressure side need a manifold gauge set. best let garage check out AC system could need system recharged or could have leak in the system.
Jun 19, 2013 | Cars & Trucks
Compact refrigerator Model 88031-1.8 cubic feet Not cooling, blown fuse in trouble shooting page, where is it located if that is the problem?
If your compressor is running there is no chance off any blown fuse but a weakness of the compressor or low gas pressure.
You can shut down and switch on after about few hours, if it cools then you must check the thermostat and the auto defrost section. If not the compressor/gas can be the suspect.
If compressor is not runningg check behind on the lower section for the relay mounted on the compressor.
Sep 24, 2010 | Refrigerators
Ac compressor is not working
CHECK AC COMPRESSOR FUSE OR RELAY.IF BOTH FUSE/RELAY GOOD.PROBABLY YOUR REFRIGERANT TOO LOW.FAULTY AC REFRIGERANT PRESSURE SWITCH OR OPEN AC COMPRESSOR CLUTCH COIL OR PROBLEMS WITH THE PCM.
Aug 06, 2010 | 1997 Oldsmobile Aurora
RS2445SH does not restart after power spike.
Some fridge units  have a delay of up to 30 minutes after power failure or short unplugging... this is to prevent restarting the compressor right away after stopping. If this is a longer delay than 30 minutes, or it never restarts without unplugging for a good while, then you might be dealing with a problem, probably with the control board. But if you see any kind of dim light or movement in any part like fan or clicking of relay beside the compressor.Then its not the control board issue.Then check out for the movement in compressor if compressor is not running then its short in compressor.
The problem is either of the 2 the main circuit board or the compressor.TRY connecting the refrigerators power wire in other power outlet then check out.If there is no power at all the circuit board needs to be checked.
For getting required parts you canget it from the on-line site like www.repairclinic.com
Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 08, 2010 | Samsung RS2534 Side by Side Refrigerator
Compressor runs for few sec. fans inside dont turn on at all
hi there, circulation of air inside the refrigerator run complete the cycle of refrigeration.if no fan your compressor motor trip off.there are fuse that hold the line connected to fans this was located at the backside of refrigerator,have check on this. replace the fuse.fix my rate have a nice day.
May 14, 2010 | True Food VWR Storage Refrigerators with...
Ge profile artica is not working. how do you change the fuse?
I believe fridges doesn't use fuses. Compressors uses a thermal protection (a breaker) located next to it, it should be next to the compressor. The compressor is located in the back of the appliance, the lower side.
Nov 05, 2009 | GE Profile Arctica Stainless Steel Top...
My refrigerator/freezer unit is not getting electricity
check your thermal fuse by compressor, then see if you can take the cover off the contactor and with an insulated stick manually start the compressor by pushing in on contactor unit on the side of the compressor
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Air Conditioning and Heat for Acura Rdx Logo
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 TE5LA
TE5LA
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
